Topic: Onan question (Read 2 times) previous topic - next topic
Onan question
Yahoo Message Number: 108109
Found one of the OHV valve cover bolts flopping loose today and was wondering what would be the appropriate torque setting? Could not find this info in the manual.
Jim C
Re: Onan question
Yahoo Message Number: 108111
If it's like most valve covers, it is sealed by a gasket, so torque is low. This also means as the gasket compresses with time and heat, the hold-downs loosen. On most cars, it is around 100 inch-lbs. In general, tighten a smidge, then fix with Loctite, barring better specs.
Re: Onan question
Yahoo Message Number: 108120
Reference the loctite. I assume you would use the blue? Also, do you put it on the threads and let it dry a bit first before screwing it or not?
Jim C
Re: Onan question
Yahoo Message Number: 108121
Jim Google Precise Engine Repair...nice site for the onan gensets. Who knew studebaker used to own the company!
Re: Onan question
Yahoo Message Number: 108123
 Sent: Thursday, December 03, 2009 8:58 AM
 Subject: [LD] Re: Onan question
Jim C
If using Loctite on that I'd go with blue (medium stength).
 Loctite thread locker is anerobic, curing in the absence of oxygen. So there's no need to let it dry before assembling. Those pre-thread locked screws, we've seen, use a different sort of thread locker.
bumper
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
