Topic: map light in cab? (Read 5 times) previous topic - next topic
map light in cab?
Yahoo Message Number: 108043
Stardust has a maplight just behind the rear view mirror with a rocker switch that appears to to have no function. It does not turn the light on. The only time the light comes on is when the ignition key is turned off. It's on a delay on turns off automatically.
Am I missing something? Is this switch supposed turn on the light?
Thanks, Richard
Re: map light in cab?
Yahoo Message Number: 108044
No, that switch is not connected to the circuit at all.
 If  you want the light on, you can turn it on by rotating the headlight switch.
 On mine, I have wired the switch into the circuit so that I can turn the light off if I have the door open for an extended period.
Monti
Monument, CO
Yahoo Message Number: 108046
"If you want the [cab interior] light on, you can turn it on by rotating the headlight switch."
Right--twist the headlight knob counterclockwise until it clicks.
Yahoo Message Number: 108061
Is "Stardust" on a Chevy? GM had lights built into the rear-view mirror that were part of the entry/dome-light system, but could also be switched on with the rocker switch on the mirror.
 A company Caprice was forever ending up with a flat battery after bing parked for a few days. It turned out that people didn't know about that light and would leave it on. You couldn't tell it was on in daylight.
