City water September 20, 2009, 11:24:44 am Yahoo Message Number: 106013I just read the section below and got to wondering.. Am I able to fill my fresh water holding tank automaticly while I am connected to city water? If that is possibly, or if I can install a retrofit device to do that, I think life would be good. I have a 96 30IB. Just wondering.. Ed
Re: City water Reply #1 – September 20, 2009, 11:35:19 am Yahoo Message Number: 106014Quote From: Ed To: lifewithalazydazerv@yahoogroups.com Sent: Sunday, September 20, 2009 8:24 AM Subject: [LD] City waterI just read the section below and got to wondering.. Am I able to fill my fresh water holding tank automaticly while I am connected to city water? If that is possibly, or if I can install a retrofit device to do that, I think life would be good. > Cheers, Don
Re: City water Reply #2 – September 20, 2009, 11:42:54 am Yahoo Message Number: 106016wrote: Am I able to fill my fresh water holding tank automaticly while I am connected to city water? If that is possibly, or if I can install a retrofit device to do that, I think life would be good. --- No, filling the fresh water tank requires a "manual outside fill", i.e., you stand there with the hose and whistle/sing/zone out/talk to somebody/plan your next trip/try to keep the water from spurting and slopping out all over your shirt and shoes/examine the "desert pinstripes" on the side of your rig/whatever while the tank fills. The "filler" on the *end* of the hose varies; I use an inline filter and a plastic fill tube, and others may use something else. Terry Tanner uses a handy creation of his own design that he calls, "The Copper Stallion"; see the photos and write-up here:http://tinyurl.com/l9dmxuJoan
Re: City water Reply #3 – September 20, 2009, 02:49:28 pm Yahoo Message Number: 106021Quote "Am I able to fill my fresh water holding tank automaticly while I am connected to city water?" Cheers, DonDon In a word, NO! The system is not designed for water to flow backwards. The pump has a diaphram which allows water to flow ONLY from it's input to the output. If, as someone posted, water flowed from the city inlet, through the pump and into the fresh water tank then something is seriously wrong with that pump. Where is the problem with running a hose to the fresh water inlet and filling the tank as it was designed to be done? ? ? ? ?Steve S. Lazy Bones & Jiggs
Re: City water Reply #4 – September 20, 2009, 04:15:46 pm Yahoo Message Number: 106024QuoteMy real question, that I did not ask, is what keeps the city water from back filling into the tank? Is there a one way check valve that could potentially fail? I do agree after hearing some of the comments that avoiding the city water hook-up all together makes sense. Ed "Am I able to fill my fresh water holding tank automaticly while I am connected to city water?"Cheers, DonDon In a word, NO! The system is not designed for water to flow backwards. The pump has a diaphram which allows water to flow ONLY from it's input to the output. If, as someone posted, water flowed from the city inlet, through the pump and into the fresh water tank then something is seriously wrong with that pump.
