Storage compartment doors. August 24, 2009, 12:02:29 pm Yahoo Message Number: 105194My project over the next weekend is to reinstall the rubber seals that are hanging loose. I have a 1996 LD and the original rubber seals are comming loose. Is there a preferred mastic I should consider that will affix the seal back in its correct position? Also while I am at it, I would like to install the metal finger loop that will help open the compartment doors. On the new LD's and other makes there is a metal finger hold that is mounted with the lock assembly. Right now I am opening a sticky door by puting side load on the key as I am opening the door. Does anyone know where I would get the finger holds? Thanks ahead of time. Ed
Re: Storage compartment doors. Reply #1 – August 24, 2009, 12:20:27 pm Yahoo Message Number: 105195Is there a preferred mastic I should consider that will affix the seal back in its correct position?Ed 3M Super Weatherstrip and Gasket Adhesive is the stuff body shops use when replacing or reattaching loose rubber gaskets. I have used it for forty years with success. http://www.shop3m.com/60455029946.html?WT.mc_ev=clickthrough&WT.mc_id=shop3m-AtoZ-Super-Weatherstrip-Adhesive> Or http://tinyurl.com/nhxg2p>Finger pulls.http://store.hemlockhillrv.com/hemlock/details.php?ITEM=3700195>Larry
Re: Storage compartment doors. Reply #2 – August 24, 2009, 12:23:42 pm Yahoo Message Number: 105196I have a 1996 LD and the original rubber seals are comming loose. Is there a preferred mastic I should consider that will affix the seal back in its correct position? Does anyone know where I would get the finger holds?Ed, Measure the width and thickness of your seals and head to your local RV parts store. Mine are 3/16" X 3/8" and I purchased a roll of Trim-Lok at Camping World. It is easy to install and provides an excellent seal. The only length that size came in was 50' so I have enough for a long time. I don't remember seeing the finger holds but they are probably available where the door locks are sold.MontiMonument, CO
Re: Storage compartment doors. Reply #3 – August 24, 2009, 06:35:50 pm Yahoo Message Number: 105218Quote My project over the next weekend is to reinstall the rubber seals that are hanging loose. I have a 1996 LD and the original rubber seals are comming loose. Is there a preferred mastic I should consider that will affix the seal back in its correct position? I dealt with mine when they were still half-way on. I used double-side tape (the foam kind, of unknown brand). I expected it might be a temporary fix, but they're still on with no separation after two (maybe even 3) years of light use.John
Storage compartment doors. Reply #4 – August 24, 2009, 10:54:27 pm Yahoo Message Number: 105225mounted with the lock assembly. Right now I am opening a sticky door by puting side load on the key as I am opening the door. Does anyone know where I would get the finger holds? Thanks ahead of time. Ed>>>>Hey Ed...I just saw one of those metal finger holds/pulls with integrated lock on www.tweetys.com http://www.tweetys.com/> . Try them.Judy Wms.Blue '07 RB "Dog Daze" andWhite '09 Scion "Puppy Daze"And all the fur kids[Non-text portions of this message have been removed]
