How Do I Operate Our Swamp Cooler? August 16, 2009, 12:08:47 am Yahoo Message Number: 104887We have a swamp cooler in our 1997 RB but I'm not sure of proper operation.best, paul"Thriving not surviving" - Paul Schaye (at 2008 NYC Marathon)
Re: How Do I Operate Our Swamp Cooler? Reply #1 – August 16, 2009, 10:00:07 am Yahoo Message Number: 104895Paul, The swamp cooler is best used in dry, hot places. It will usually drop the temperature about 10 degrees.Here's the steps. - Turn on water pump (if not hooked to city water) - Find the cutoff valve and turn it on. In my 1995 22' twin/king, the valve was in the storage cabinet beneath under the sink. - Let the water run for a few minutes until the reservoir in full. There is a float that will shut the water off when it's full. - Turn on the swamp cooler pump and let it run until the pad is totally wet. - Open a few windows an inch or two. You can somewhat control where the cool air goes by adjusting what windows you open and how far you open them. - Turn on the swamp cooler fan. - Enjoy.Bob Coulter Albuquerque, NM
Re: How Do I Operate Our Swamp Cooler? Reply #2 – August 16, 2009, 10:05:46 am Yahoo Message Number: 104896Thanks, Buck! My guess is that Summer in El Centro, CA will qualify as hot and dry (annual rainfall less than ONE INCH)best, paul"Thriving not surviving" - Paul Schaye (at 2008 NYC Marathon)
Re: How Do I Operate Our Swamp Cooler? Reply #3 – August 16, 2009, 06:15:41 pm Yahoo Message Number: 104944Hot and Dry is right! But remember that a swamp cooler only lowers the temperature a bit. At 110 degrees or so, it isn't going to do much for your overall comfort level.[Non-text portions of this message have been removed]
