Electrical cord update August 03, 2009, 01:44:29 pm Yahoo Message Number: 104448I got the cord plug switched out to a new one...interesting (to me), when I started stripping the wires to be attached to the new plug, the black wire was blackened for about 18" - that's how much I ended up cutting off the cord. I figured the blackened wire was not healthy. At some point (sooner than later), I will completely switch out the house cord.Got the generator running again with a new fuel filter and air filter.Thanks for Everyone's help on this!Cheers, Helen (with SOB)[Non-text portions of this message have been removed]
Re: Electrical cord update Reply #1 – August 03, 2009, 01:56:11 pm Yahoo Message Number: 104450"I got the cord plug switched out to a new one...interesting (to me), when I started stripping the wires to be attached to the new plug, the black wire was blackened for about 18" "Helen The blackened wire is probably the result of moisture getting into the wiring insulation. Give all the screwed connections a good coating of dielectric grease and seal things if possible.Larry
Re: Electrical cord update Reply #2 – August 03, 2009, 02:16:32 pm Yahoo Message Number: 104451Hi Larry - I was thinking of using some glue on the cord handle where the pieces meet.What is dieltric grease, and where does one get it?Helen
Re: Electrical cord update Reply #3 – August 03, 2009, 02:31:39 pm Yahoo Message Number: 104452"What is dielectric grease, and where does one get it?"Helen Dielectric grease is a NON-conducting grease that seals out moisture and therefore prevents corrosion on electrical connectors. I use it on all sorts of electrical connections, plugs and light-bulb bases to keep the contacts clean and conductive. It is also sold as 'Tune-up grease'. It is available at most auto parts, marine hardware and electronic stores. http://tinyurl.com/ah9gggLarry
Re: Electrical cord update Reply #4 – August 03, 2009, 02:36:02 pm Yahoo Message Number: 104453Quote What is dieltric grease, and where does one get it? Available at any auto parts store. Just ask for dielectric grease. On your trailer or toad light plug, its a good idea to clean your plugs, both male and female, with a spray contact cleaner occasionally and apply some dielectric grease to insure good connection.
