2000 LD 26.5 IB specs brochure needed August 02, 2009, 08:45:15 am Yahoo Message Number: 104399Cannot locate the site where the initial brochure is filed. Looking for information regarding the city water inlet. Is there a pressure regulator built in? Thanks for any help. Norma [Dazey and DD]
Re: 2000 LD 26.5 IB specs brochure needed Reply #1 – August 02, 2009, 09:27:43 am Yahoo Message Number: 104401"Looking for information regarding the city water inlet. Is there a pressure regulator built in?" No; you'll have to buy one; most RV stores sell them. Or you can do what many of us do: don't hook up to city water at all. Just fill the freshwater tank, draw from it until it gets low, refill, and so on. If you connect to the city water outlet most of the time and only draw from your freshwater tank once in a blue moon, the water sitting in that tank can get pretty nasty. By keeping water moving through the freshwater tank, you keep it fresh. And of course you need never worry about city water pressure when filling the tank. :-) The Lazy Daze spec sheets are in the Yahoo "Techsnoz" group's Files area. Go to this URL:http://autos.groups.yahoo.com/group/Techsnoz> Join the group, if you are not already a member. Then click on the Files link at the left of any page, and you'll see all the spec sheets listed.Andy Baird http://www.andybaird.com/travels/
Re: 2000 LD 26.5 IB specs brochure needed Reply #2 – August 02, 2009, 07:10:32 pm Yahoo Message Number: 104427Thanks for the reply. We are members, and have been full-timing for 15 years, so are very careful to always use a pressure regulator as we usually hook to city/or well water! I was just curious about a built-in and could not find the brochures that I had recently seen. Thanks so much for the link. Norma
