water heater problems July 25, 2009, 04:16:42 pm Yahoo Message Number: 104175changed the controller card on water heater in LD rear bath (86) it will not stay light runs a minute and turns off. That is why I changed the old controller card. Does one have any ideas what is wrong with the water heater.
Re: water heater problems Reply #1 – July 25, 2009, 09:59:14 pm Yahoo Message Number: 104195Been there - done that. After installing the new controller with no success, it was discovered that the wire to the igniter was loose inside. Seems that the igniter is also the keep-alive sensor. The loose wire made enough contact to fire the igniter but not for the sensor to function. A new igniter (couple dollars) cured the problem. The $100 card is now on the shelf as a spare :-(Good luck with yours,ray--firejones wrote:
