Topic: air conditioner problems (Read 9 times) previous topic - next topic
Yahoo Message Number: 103854
Hello; I finally dewinterized my RK and the water system works fine.  However, when I turned on the Air Conditioner, powered by the genset, it would not come on.  I had this problem on previous RV's and was told the motor freezes.  Anyone here no how I can unfreeze the motor?  Once I remove the cover what should I look for? Dometic warrants the AC for 3 years but I doubt if there are any dealers here in Nova Scotia.  Thanks for any ideas.
Mike
2007 RK
Re: air conditioner problems
Yahoo Message Number: 103856
Hello; I finally dewinterized my RK and the water system works fine.  However, when I turned on the Air Conditioner, powered by the genset, it would not come on.  I had this problem on previous RV's and was told the motor freezes.  Anyone here no how I can unfreeze the motor? >
Don't know if this will help, but if you turn the air conditioner on too
soon after starting the genset it may not work properly.  Give the
 generator maybe 5 minutes to adjust itself before firing up the AC and
then see what happens. Just a thought.
JC
