Fuel pump for 2005 Ford E450 v10 June 20, 2009, 12:48:31 pm Yahoo Message Number: 103458I have been getting occasional P0191 engine trouble codes. The Ford dealer in Dawson Creek said it is because the fuel pressure got below 48 PSI. Neither they nor any Ford dealer in the area had the pump. Anyway, I am thinking of getting one for a spare in the event the old fuel pump gives out. My problem is figuring out what would work as people that sell the pumps have several choices. Here is a list:AIRTEX Part # E2437S {Assembly w/ Sender} w/Rear Tank - $240.79 MOTORCRAFT Part # PFS330 Midship Tank w/Aux Fuel Port - $251.79 MOTORCRAFT Part # PFS303 {#6C2Z9H307AA} Midship Tank w/o Aux Fuel Port - $292.79 MOTORCRAFT Part # PFS298 {#6C2Z9H307CA, PFS158} Aft Axle 37/55 Gal Tank - $361.79 BOSCH Part # 69156 {Fuel Pump Assembly} Midship tank; w/o Auxiliary Fuel Ports - $315.79 BOSCH Part # 69157 {Fuel Pump Assembly} midship tank; w/ Auxiliary Fuel Ports - $315.79 Clearly, we would have the midship tank. But do we have the aux fuel port? Incidentally, the Ford dealer in Dawson Creek said the part, if they had one, was about $670 CDN. Obviously, there's a bit of a mark up there! So, would a mechanic out there educate me please? What would you get?Alex Ruthka '05 MB[Non-text portions of this message have been removed]
Re: Fuel pump for 2005 Ford E450 v10 Reply #1 – June 20, 2009, 01:00:14 pm Yahoo Message Number: 103459I work for a Wholesale Auto-Parts on Saturdays, and just looked up your application, be careful you are not comparing apples-and-apples. The airtex E2437S shows: Rear tank.So that would mean aft of the rear axle. If yours is in front of the rear axle Airtex calles out: E2364S if there are 3 ports E2365S if there are 2 ports My understanding is that the third port is if there are two tanks on the truck.Looks like you will be crawling under there to take a peak. Btw, that price of $240 for the Airtex E2437S is pretty competitive. I do believe that Denso was the original manufacturer, and they list it as: 953-4033 for Aft tank 953-4040 for midship tank with auxiliary fuel portHope this helps a wee bit.Ken Sannwannabe in SoCal
