Topic: EternaBond Nightmare! (Read 10 times) previous topic - next topic
Yahoo Message Number: 102840
Last week we applied EternaBond to the seams and vents on the roof of our LD
The roof was pressure washed and allowed to dry for several days.
The areas where cleaned with lacquer thinner and wiped before application of the EternaBond.
At this point I'm totally disgusted... The stuff appears to be releasing from the roof with pockets developing underneath and just coming lose all over. Even the place where the seams where overlapped, the product isn't sticking to itself. Any ideas?
 Products used Eternabond White Micro Sealant Leak Repair Tape - 4" x 50' Roll
Thanks
Ellen
Re: EternaBond Nightmare!
Yahoo Message Number: 102841
our LD
application of
the EternaBond.
50'
Roll
Thanks Ellen
did you rub the tape with plenty of pressure or use a roller? the eternabond will not stick to silicone eithier...
rob
Yahoo Message Number: 102842
EternaBond will not stick to silicone either...>>
 I sure did and I realize that it doesn't stick to silicone per instructions.
Thanks for your response:)
Ellen
Yahoo Message Number: 102843
That was my first guess, too. It needs good firm pressure; I used a seam roller from my wallpapering kit.
 Another possibility is that it was too old; IIRC the official shelf life of Eternabond is 5 years. Where and when did you buy it?
Joanne in Boston NE-44
Yahoo Message Number: 102847
Here is one possibility, Ellen
Lacquer thinner:
 Used to dilute, dissolve and clean up of lacquer products. Typically too caustic for oil paints, lacquer thinner is often used additionally for removing inks on metal, and adhesive residue from a variety of surfaces. Lacquer thinner is very  strong and rapidly deteriorates many surfaces and fabrics. Always test in inconspicuous area before use.
Ed
Yahoo Message Number: 102848
Thanks Ellen
Ellen, most of us used Eternabond Roof Seal white and not the Micro Sealant.  They carry slighty different stock number.  I wonder if there could be any appreciable difference that would cause problems.
 http://www.bestmaterials.com/detail.aspx?ID=11341 Joe Hamm-San Jose
Yahoo Message Number: 102849
Lacquer thinner:>>
http://tinyurl.com/mse9v4
 According to the EternaBond website instructions... It suggests using Lacquer thinner.
What are my options now?
Thank you for your response.
Ellen
Yahoo Message Number: 102850
 http://www.bestmaterials.com/detail.aspx?ID=11341 Joe Hamm-San Jose>>
Joe, I believe that the product is one of the same.
Please note the contents under composition in the article in the link you just sent It states...
COMPOSITION: Eternabond RoofSeal utilizes Eternabond's advanced MicroSealant technology.
 It features a 100% solids proprietary formulation of synthetic resins, thermoplastics and non-curing rubber (not butyl) and a built-in primer.
 The MicroSealant is bonded to a tough UV staple backing. The facing side of the MicroSealant is then covered by an easily removed plastic release liner
 The link of the EternaBond that I purchased, I found via Andy Baird's Eureka cd.
Thank you :))
Ellen
Yahoo Message Number: 102851
the micro sealant version is the same as the rv white tape.. they both have the micro sealant
Yahoo Message Number: 102852
Ellen, I had a thought that may or may not apply.  Was the area to be covered clean of old caulk?  If there was still caulk present, the lacquer thinner MAY have softened or partially dissolved the old caulk.  The caulk may then have still been a bit soft when you applied the tape.  That may have been a factor.  Perhaps someone else here will have more data on the interaction between thinner and caulk.
This is TOTAL guesswork on my part.  To test it, I would put some thinner on the caulk, wait a few minutes, then touch the caulk to see if it was made tacky by the thinner.
It sounds like you have a real headache with that, and I sympathize.
I hope someone here can give you the answer.
Ken
Yahoo Message Number: 102856
http://tinyurl.com/nn9gq ...pics of some of it coming lose.
I purchased the EternaBond at  rvupgradestore.com as well as the EternaBond Roof Vent Installation Kit for my bathroom vent that we just installed. We also pulled the AC and the swamp cooler and resealed them as well.
Ellen
Yahoo Message Number: 102857
Ellen
When I looked on the link you gave Eternabond had a phone number at the end. It was 888-336-2663.  Maybe they can help?
Nancy in Atlanta
Yahoo Message Number: 102859
"The stuff appears to be releasing from the roof with pockets developing underneath and just coming lose all over. Even the place where the seams where overlapped, the product isn't sticking to itself. Any ideas?"
Ellen
 If the Eternabond does not stick to itself, on the overlaps, the roll may have been contaminated somehow.
I assume that your roof has not previously been coated with an aftermarket sealant and that you are applying the tape to the Factory painted roof. I have sealed at least a dozen roofs with Eternabond and the stuff has stuck every time. I have used both lacquer thinner and acetone to clean the roof.
 Is this a previously owned rig? If so, the PO might have coated the roof with some type of silicone sealant or wax. Any type of silicone will prevent the Eternabond from sticking. It could also contaminate the tape and keep it from sticking to itself.
The best way of making sure any silicone spray or wax has been removed is to use a pre-paint cleaner that is made to remove silicone. An auto paint store will have it or you can get it online.
http://www.eastwoodco.com/jump.jsp?itemID=408&itemType=PRODUCT>
 Poking a small hole in the bubble, with a sharp Exacto knife, and then rolling the air out normally can fix bubbles.
Good luck and let us know if you find a solution.
Yahoo Message Number: 102867
Ellen, I'm very sorry to hear that you and your husband did all that work and had poor results. I can imagine how frustrating that must be! If your Eternabond won't even stick to itself, I'd be inclined to think that the tape itself was defective. In any case, if I were in your situation, I'd call up the company and see what they suggested. Do you have any of the tape left over? They may want to examine it to see what went wrong.
 It wouldn't hurt to try rolling it down firmly, after puncturing the bubbles with a sewing needle. (Don't worry, the sticky rubber will close around the tiny holes you make.) But I'd talk with Eternabond first.
 Please let us know what you find out. This is the first time I've heard of an Eternabond adhesion failure on a properly prepared roof*, so if there's a trick or something to avoid, we'd all like to know about it.
 * I did have a few places on Gertie where Eternabond came loose, but that was because I hadn't been able to clean properly under the solar panels, which cover almost the entire roof.
Yahoo Message Number: 102880
bubbles with a sewing needle. (Don't worry, the sticky rubber will close around the tiny holes you make.) But I'd talk with Eternabond first.>>
 Thanks Andy:)) The Eternabond that we have is not as sticky as what they show on the web site. As I have stated, It release from itself and it shouldn't do that. We have punctured the bubbles and again rolled over on all the seams... It is just not going to stick. The company stated that we prepped it correctly and are assuming that we left the liner on. This not being the case!
 To remove all the Eternabond and reapplying is going to be a nightmare!
Ellen:))
Yahoo Message Number: 102907
Not trying to be smart but just covering all ideas to be helpful; did you remove the clear release film on the adhesive side of tape to expose the adhesive as you installed it?  Just a thought since the tape will stick on the edges without removing the film!
 If this is not the case I would call Eternabond and see if they can shed some light.
Good luck and hope an answer and solution comes your way.
Yahoo Message Number: 102911
Hi Kent,
 Thank you for your response on my Eternabond dilema. Please note, that on more recent posts, I have addressed the issue regarding that the clear release film was removed. I have been in contact with the company as well.
 According to the person whom I spoke... Out of over a million rolls sold, only 100' of it seems to have had some type of failure.
Plus mine of course:) I would say that is a very low failure ratio. Although I wished I was one of the success stories:) It is what is and we will see what can be done about it.
A communication I received this morning...
 The rolls are being shipped out to you, again I am sorry you experienced problems.
 In my previous E-mail, I was not referring to you not removing the release liner. What I meant was that the tape is easier to work with on long runs (even as short as 7 feet) if you pull back the release liner about a foot at a time as you go along laying the tape. I knew that you had not left release liner on when you applied it. I hope this clarifies what I was trying to convey.
All the best,
