Topic: Trouble with generator (Read 2 times) previous topic - next topic
Yahoo Message Number: 102313
I need some advise.  I have a 95 LD with the Onan generator.  Today when I tried to start the generator it would start and run only as long as I held down the start switch.  As soon as I let the switch go to the center position the generator died.  Using the switch at the generator instead of inside, the same thing happened.
Any thoughts?   Thanks Ed
Re: Trouble with generator
Yahoo Message Number: 102315
I have a 93RB and sometimes my unit does the same thing.  This usually occurs after the rig has sat for some time and the genset has not been run.  I usually have to let it run for a couple of minutes with the start button held down (once or twice) and then the unit finally catches.  I am assuming that the unit needs to clear the "stale" fuel in the line or reservoir bowl.  I typically do not drain the glass bowl as recommended before storage.  However, this protocol has worked for me w/o fail.  Good luck!!
Yahoo Message Number: 102316
Well, Ed, if you have been exercising the generator every month, I would have no idea.  But, if you haven't, the carburator is gummed up and needs work.  Not a trivial job.
Alex Rutchka
'05 MB
Yahoo Message Number: 102317
Actualy is was running great a week ago.  This definately electrical, unless it's electric fuel pump? Ed
Sent by mobile phone
Yahoo Message Number: 102318
Probably no gas.  Disconnect the fuel line at the input to the filter/pump and seeif you get gas pumping into a container.  Larry
Yahoo Message Number: 102321
"Today when I tried to start the generator it would start and run only as long as I held down the start switch. As soon as I let the switch go to the center position the generator died."
1. Is your fuel tank less than 1/4 full? That'll cut off fuel to the generator... a feature designed to prevent you from running the tank dry and then not being able to move the rig.
2. Have you checked your generator's oil level? The Onan generator has a sensor that will shut it off if the oil level is low.
Hope this helps!
