Topic: Why did LD limit the charging rate to 40 amps? (Read 8 times) previous topic - next topic
Yahoo Message Number: 99306
On my 82 LD FL, the factory put a 40amp fuse between the isolator and the coach battery.
1) If I were to upgrade my alternator to 100amp, should I also change  that fuse to 60amp or higher?  Of course I also need to upgrade the  wire as well.  Would this cause any problem?
2) Is that fuse really necessary?  What problem is it trying to prevent?
Thanks,
Sam
Re: Why did LD limit the charging rate to 40 amps?
Yahoo Message Number: 99308
Hi Sam,
I suspect they chose the fuse based on the wiring they installed for that circuit.  Most automotive fuses are there to protect the wiring in the vehicle.  An ex-boss of mine can attest to this after he defeated a fuse in his car and then the pillar between the windshield and the door got too hot to touch.
...snip...
...snip...
Safe Travels, Dave N 2000 RB Albuquerque
Dave
2017 TK
Yahoo Message Number: 99323
That's what I initially thought too.  But that's not the case.  This is a 6 foot long wire, which begins at the isolator and ends at the coach battery positive post.  The fuse is positioned about 4 ft from the isolator and 2 ft from the battery.  So the only thing it can protect is the last 2 ft of wiring.
Sam
Yahoo Message Number: 99328
I looked at it more carefully, and it's actually a sophisticated fuse: 40amp Auto Reset Circuit Breaker.
Still don't know what it's for.
Sam
Yahoo Message Number: 99329
"The fuse is positioned about 4 ft from the isolator and 2 ft from the battery. So the only thing it can protect is the last 2 ft of wiring."
A fuse anywhere in a circuit protects the whole circuit, since electricity stops flowing in the whole circuit when the fuse blows.
Yahoo Message Number: 99335
Of course, you're right, Andy, in theory.  However in this case the isolator does not draw current, the battery does.
Yahoo Message Number: 99337
"you're right, Andy, in theory."
And in practice. :-) This isn't hair-splitting, it's simply the way electricity works. There's no such thing as a fuse that protects the wire on one side of it but not on the other side. When a fuse blows due to excess current (and remember, current is by definition the same at all points in a series circuit), the entire circuit is de-energized, preventing overheating and fire.
The answer to your original question--why did Lazy Daze put the 40A fuse there?--is the same as for any fuse or circuit breaker: it was put there to prevent excessive current (due to a short circuit, component failure, or other reason) from causing a fire. In other words, there's no great mystery here, just standard electrical engineering practice.
Yahoo Message Number: 99338
 Sent: Saturday, February 14, 2009 8:38 PM
 Subject: [LD] Re: Why did LD limit the charging rate to 40 amps?
Andy,
 Respectfully, that's not my understanding. Consider a fuse installed some distance from the battery in a chassis ground (negative) system like our LDs. Let's say the fuse is 2 feet away from the battery and wired in series with the positive battery terminal. That fuse will protect only that portion of the circuit (wire etc) downstream or  further away from the battery than is the fuse.
 e.g. if the wire one foot from our battery should chafe through and touch chassis ground, there will potentially be a catastrophic failure (much spitzen sparkin!) and the fuse will not blow or protect from this. Current will flow from the negative battery terminal through the chassis (ground), to the chafed shorted wire and then back to the battery positive terminal completing the circuit. Note that this current surge will not go through the fuse.
 It should be obvious why it is considered good practice to install the fuse panel, or a main, larger fuse as close to the battery as practicable.
all the best,
 bumper (ex Navy Electronics Tech, licensed electrician in CA - - - though I sure wouldn't want to live in a house I wired.) Yonder
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 99341
Sam, our '83 has two of these mounted on the firewall, one protecting the run from the battery to the isolator, the other from the battery to the converter panel. The coach battery can deliver hundreds of amps if either line develops a short, so as Andy said, they protect the wiring runs and prevent a fire. Of course the short pigtails from the battery to these CB's COULD develop a short, but it is both unlikely and not as dangerous if they incinerate.
Yahoo Message Number: 99343
Steve,
Yes, I saw the second one (going into the coach) too, and that one makes sense to me.
 So, it appears to me that it does not make a lot of sense to upgrade to a higher capacity alternator if one were to keep the same one wire circuit from the isolator to the battery.  Am I missing something?
Thanks,
Sam
Yahoo Message Number: 99344
..., the other from the battery to the converter panel.
Steve,
 I saw a 0.3V drop across this circuit breaker under a 90watt load (3 fluorescent lights on), and the circuit breaker was a little too warm (not hot) to the touch.  Is that normal?
Thanks,
Sam
Yahoo Message Number: 99346
Yes. If what you have currently is a 45A alternator, that must supply about 25A or so to the headlights on brights, plus all the running lights, plus ignition, plus charge a chassis battery possibly depleted from a cold morning start, plus supply any 12V accesories in the coach you are running enroute, including 15-20A to the fridge.... AND charge a coach battery you may have depleted in several days camping. I also am led to believe you may soon be more than doubling the capacity of your current coach battery. All this really calls for a higher charge capacity.
Most of us who have done upgrades have also replaced some of the wiring and those circuit breakers. Since I no longer have a coach battery up front, I also upgraded the wiring to the new location, replacing the circuit breakers with a binding post, and installing a pair of 100A fuses in the new location.
Yahoo Message Number: 99347
Normal at the age...but not good. You can get good high-amperage fuses and fixtures at high-end car audio outlets (including Walmart), intended to supply amps pumping out 1000 watts of sub-bass. Fuses are better - no internal contacts to deteriorate.
Yahoo Message Number: 99348
Thanks, Steve.  I currently have a 64amp Duralast alternator.  I plan to upgrade my current 75AH battery to either a single 125AH battery (engine compartment) or two 125AH batteries (right side, underneath lounge area.
Sam
Yahoo Message Number: 99350
Excellent.  Will do that when I upgrade the battery.
Sam
Yahoo Message Number: 99351
"if the wire one foot from our battery should chafe through and touch chassis ground... the fuse will not blow or protect from this. Current will flow from the negative battery terminal through the chassis (ground), to the chafed shorted wire and then back to the battery positive terminal completing the circuit. Note that this current surge will not go through the fuse."
 You're right; I wasn't thinking of that scenario. My apologies  to Sam for not understanding the setup he was describing.
Yahoo Message Number: 99383
" I currently have a 64amp Duralast alternator."
Sam An important fact to remember is that automotive alternators only produce their rated output when the alternator is cold. As they warm up, the output can significantly decrease.
 A few years ago, I pulled a 63-amp Delco alternator off a co-worker's MH and put it on the alternator-testing machine at work.
It produced 60-amps cold but then dropped down to 45-amps after running under load for ten minutes.
45-amps is not enough output to provide much charging to the batteries when the engine, dash A/C and headlights are operating.
Ford got it right when it started installing 130-amp alternators in the E350/450 cutaway chassis.
Yahoo Message Number: 99384
worker's
Thanks, Larry, for the info.  There is one more piece of information that seems to be missing.  For example, I'm looking at this 94Amp alternator, and I can't find the RPM (alternator, not engine) at which it is rated.
BTW, my current one is a 63amp alternator too (I mistyped 64 in the previous post.)
Sam
Yahoo Message Number: 99386
"There is one more piece of information that seems to be missing. For example, I'm looking at this 94Amp alternator, and I can't find the RPM (alternator, not engine) at which it is rated."
Sam
This is the type of information that has mostly disappeared with electronic catalogues. Back in the day of paper catalogues, there was a great deal of information available.
FYI. From my own experience, most alternators are set up so they provide maximum output at 1800-2000 engine RPM.
Alternators usually spin at 2-3 times faster than the engine so figure 4000-6000 RPM.
Some alternators are set up to provide high output at or near idle.
Many times these will be labeled for police or ambulance use, vehicles in which long periods of idling are common.
You will find that these alternators have a smaller pulley that increases spin speed at low RPMs.
Yahoo Message Number: 99403
Andy,
 I hate to disagree with you, but I think you haven't considered all options.
 If there is a short to ground on the battery side of the fuse, the wire from the battery to the short can and possibly will melt and cause a fire.  The fuse is only for the portion of the wire after the fuse.
A fuse should be put as close to the energy source as possible.
 I had this pointed out to me by an airplane mechanic after I installed a new digital clock (almost unheard of at the time) improperly.
Barry Where are we?  http://map.datastormusers.com/user1.cfm?user=122
