Topic: Loose screws (Read 3 times) previous topic - next topic
Loose screws
Yahoo Message Number: 99180
It seems that the various drawer pull screws constantly are somewhat loose despite tightening them. Has anyone else run into this and did you find a solution?
Jim C
Re: Loose screws
Yahoo Message Number: 99181
somewhat loose
find a
solution?
Jim C
Jim
Try using 'Loctite' applied to the threads and your problem will go away.
Lazy Bones & Jiggs
Re: Loose screws
Yahoo Message Number: 99219
"It seems that the various drawer pull screws constantly are somewhat loose despite tightening them.'
Jim
 While Loctite and super glue will keep the screws tight; you may never be able to remove the screws in the future.
I find that a drop of white or yellow glue will keep things tight while allowing for future removal.
For critical mechanical parts, it's Loctite all the way.
BTW, Loctite is available in several degrees of strength.
I use the green a lot. It can be applied to already assembled clean hardware. Save the red Loctite for things that will never be disassembled.
http://tinyurl.com/2llln>
Re: Loose screws
Yahoo Message Number: 99221
If you do have to remove Loctite, or some other adhesive that's been used to secure a fastener, the first step is to use a reasonable amount of force (torque) to do the job. Don't overdo it though, as the fastener may break or strip out.
 If a high strength adhesive threadlocker (like red Loctite) was used, then heat (about 200 degrees should do) will aid disassembly and perhaps prevent damaged fasteners. A propane torch can be used to apply the heat. If there are combustible materials or things that must be protected nearby, you can make a heat shield, with a suitable hole in it for the object, from aluminum flashing etc.
all the best,
bumper Yonder Minden NV
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
