After freezing weather turned on water pump and got spraying water January 19, 2009, 12:04:49 am Yahoo Message Number: 98664What a winter! I thought we made it through the Dec snow, ice and freezing temperatures O.K. - when I checked the 30 foot Island-Bed LD for damage due to freezing liquids I found none.But... This morning when I turned on the water pump, I heard a "spraying water" sound, and immediatly turned it off. Then went to inspect the pump / compartment under the bed - no surprise - I had water to clean up. I don't know if it has anything to do with the under-freezing weather we had for 2 weeks or is an unrelated issue, but I need to have someone check it out. Can anyone recommend an RV service/maintenance center in the greater Seattle area that has done good work on their LD?Diane and CourtneyP.S. We live in Bellevue, and prior to our trip this fall to Yellowstone took the AGLBGL in to Camping World in Tacoma for a 30+ point inspection - was quite disappointed in their service - don't want to go there again.
Re: After freezing weather turned on water pump and got spraying wat Reply #1 – January 20, 2009, 08:32:01 am Yahoo Message Number: 98689"...This morning when I turned on the water pump, I heard Quotea "spraying water" sound, and immediatly turned it off. Then went to inspect the pump / compartment under the bed - no surprise - I had water to clean up. I need to have someone check it out. Can anyone recommend an RV service/maintenance center in the greater Seattle area that has done good work on their LD?Diane and Courtney Diane and Cortney, You can find recommendations in the Data Base under "Maintenance and Installation Facilities." Several years ago I found a post in there by Sarah Blackwood praising the work done at Eric's RV Performance Center in Sequim WA. I have been going there ever since. It is a hundred miles from my house in University Place and farther from Bellevue. Still, it is a pleasant drive and location and the quality of support I get from "Spud" who works on my 2005 30TB makes the trip worthwhile. I recommend Eric's to you for your present problem or for any future needs. Nate Walker Tacoma
