Topic: Frozen black tank (Read 7 times) previous topic - next topic
Frozen black tank
Yahoo Message Number: 97893
I have some frozen waste in my black tank.  I tried to thaw it with hot water thru toilet...no good.  Black tank is almost full.  I can't go south for 4 weeks and now everything will freeze solid.  Do I have to worry about the tank bursting?  How long in warm weather (let's say 55) does it take to thaw?
Bob '05 30IB
Re: Frozen black tank
Yahoo Message Number: 97894
Try dumping a gallon of RV antifreeze down the toilet.  It's about 4.00 a gallon at walmart.  Might get it liquid enough to dump.
Yahoo Message Number: 97895
Can't answer your question. However, you might consider draping a blanket or tarp around the outside edges of your tank so the covering drapes down to the ground. Then put an electric heater (cube type with fan, not a radiant heater for fire concerns) under the tank. That should have it defrosted in short order.
bumper Yonder (with heated RV garage!!)
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 97897
Bob, I had this happen in Monument, Col. just before we took off a month ago. I drove over 5o miles in sunny weather but on the cold side. It finally thawed and I was able to dump. Being that you will be there 4 weeks. You may want to put a light bulb beneath the area and leave it on closeby. I tried the antifreeze bit and it may have helped but better weather and some warmth underneath should help. Good luck, john leach
__
