Sagging rear leaf springs and low front clearance November 11, 2008, 06:59:41 pm Yahoo Message Number: 97188When I had to replace a failing muffler on my 2000 MB, and was able to look under the coach. I noticed that the two rear leaf springs where "frowning" instead of "smiling". Normal rear leaf springs are in a U shaped and therefore smiling. The black and gray tank were empty as well as the water tank and water heater. I just winterized the coach.Does anyone in this group has noticed this and is this normal for a 2000 MB and what is the solution to correct this situation? Also I have noticed in the past that the coach is leaning down in the front no clearance to put a board under my HWH kickdown levelers. Again is this normal?It will be very much appreciated to hear your comments.Frans Liebert 2000MB Lake St Louis, MO
