Factory "stealth" options October 30, 2008, 01:23:29 pm Yahoo Message Number: 96993With all the switching around of TV technology and such, I found myself wanting to run new wiring for the new HDTV up to the top (sat receiver) shelf. This required drilling a larger hole up through the shelf near the back. There is virtually no room to get a drill motor and bit in there (though I was able to do the deed using a right angle aircraft type air drill and a modified hole saw bit) - - hardly a tool you'd find in most shops. Bottom line, if I were ordering a new LD, I would ask them to provide 2" wiring access holes at the back of all the TV shelves, and install a 110 VAC outlet near there as well.all the best,bumper[Non-text portions of this message have been removed]
Re: Factory "stealth" options Reply #1 – October 30, 2008, 11:55:13 pm Yahoo Message Number: 97005Message 89034
