Topic: Water leak (Read 95 times) previous topic - next topic
Water leak
Yahoo Message Number: 90146
I hava a 99 LD Rear Bath.  I have a leak, I think, at the connections to the shower.  In order to access it I think the sink cabinet needs to be removed.  Has anyone ever done this without destroying the wall? Thanks.........
Re: Water leak
Yahoo Message Number: 90162
Jim, I recently had a small leak under the kitchen/bath area.  Turned out it was caused by a malfunction in the water pump.  I had a technician replace it and it's working fine now.  So...you might want to check your Shurflo waterpump first. Be sure to get the "Whisper King" as it is much quieter. Hope this helps.  David
jimmoregon jmorgan1@...> wrote: I hava a 99 LD Rear Bath. I have a leak, I think, at the connections to the shower. In order to access it I think the sink cabinet needs to be removed. Has anyone ever done this without destroying the wall? Thanks.........
Looking for last minute shopping deals?  Find them fast with Yahoo! Search.
Re: Water leak
Yahoo Message Number: 90167
Our pump was replaced on warranty after a mere 89 days of ownership (2007 26.5 RK) for leaking.
David Roderick dave3639@...> wrote:          Jim, I recently had a small leak under the kitchen/bath area. Turned out it was caused by a malfunction in the water pump. I had a technician replace it and it's working fine now. So...you might want to check your Shurflo waterpump first. Be sure to get the "Whisper King" as it is much quieter. Hope this helps. David
Mike and Gloria Walsh Auburn, Alabama '07, Teal 26.5 RK Following the sun in retirement in "The Walshmobile".
Re: Water leak
Forgot about this.  But it was the water pump.  All's been well since.  150,000 mi.  on our 99 RB party model. 5 months boondocking in AZ every winter and it just keeps on going.
