Beeping in a 26'MB! Can't find it!!!Help! January 20, 2008, 08:42:28 am Yahoo Message Number: 88602Hi Folks Hope someone out there can help! There is a very slow beep coming from the lounge area of my 26'MB. It is a single beep spaced erratically 5 minutes or more apart. I have searched, removed batteries from all sorts of things in that area. I've also checked the batteries of the smoke & CO2 detectors & can find nothing. Has anyone else experienced this? Does someone have a fix?Thanks tons, Pat
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #1 – January 21, 2008, 05:17:08 pm Yahoo Message Number: 88660Hey Pat, Someone on here who found a timer stuck behind a kitchen drawer. Do you have a hidden timer somewhere whose batteries might be running out? One more thought... I'd be very suspicious if Steve of Lazy Bones fame was hanging around your rig lately, if he's looking at such products as the "Annoy-A-Tron" mentioned
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #2 – January 21, 2008, 06:24:25 pm Yahoo Message Number: 88664Just a thought Pat, disconnect the coach batteries and see if it continues. If it doesn't continue you have isolated it to something with
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #3 – January 22, 2008, 12:23:04 am Yahoo Message Number: 88681Pat, If you have the factory installed 400 watt inverter for your TV it could be the sound you are hearing. It will beep when the house batteries get low. It is located under your refer, behind the lowest cupboard, behind the partition mounted vertically on the wall. Steve
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #4 – January 22, 2008, 12:41:23 am Yahoo Message Number: 88683Quotesorts of things in that area. I've also checked the batteries of the smoke & CO2 detectors & can find nothing. How about the propane detector?Steve
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #5 – January 22, 2008, 06:34:00 am Yahoo Message Number: 88688Thanks Folks Found the beep! Coming from my Acurite wireless thermometer that I've used for years. Don't know why but plan to call them today! Pat
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #6 – January 22, 2008, 09:03:30 am Yahoo Message Number: 88689" wrote: Found the beep! Coming from my Acurite wireless thermometer that I've used for years. --- Maybe it just needs a new battery?Joan
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #7 – January 22, 2008, 09:41:15 am Yahoo Message Number: 88690Quote " wrote: Found the beep! Coming from my Acurite wireless thermometer that I've used for years. --- Maybe it just needs a new battery?Joan Did it, by chance, get its low (or high) temperature alarm set?Linley
Re: Beeping in a 26'MB! Can't find it!!!Help! Reply #8 – January 22, 2008, 06:20:37 pm Yahoo Message Number: 88718According to the tech that called me, the unit beeps when there is unusual interference. Since it has happened since I've changed sites that might make sense. It'll be interesting to see if it still happens when I move on Feb. 1!
