Topic: Aquarium thermometer (Read 3 times) previous topic - next topic
Yahoo Message Number: 87100
http://www.valuetesters.com/Mannix-AQ150-Digital-Aquarium-Thermometer.php
Should the link not work just google aq150. Brand is Mannix
Price is $18.00 and temperature range is -58 to +158F
 For the LD rear bath we put the wire through the night light opening and tucked the sensor into the foam insulation around the water heater as others suggested. The display is on the wall between the stove and refrigerator. The other suggested thermometer may be of better quality but this one works and the temperature range is more than adequate.
Harry
Harry 2006RB
Re: Aquarium thermometer
Yahoo Message Number: 87149
Harry,
 I realize it is subjective, but at what temperature do you (and any others that want to reply) set the hot water temperature alarm?
 Doing a Google search seemed to indicate that shower temperatures were in the 110 to 125 degree range.  Is this in agreement with your (or any other person's) experience?
 We have an alarm on order, and I would like to have a good starting point to save time before we experiment to find our 'own' temperature.
Barry 2001 Red RB, TX Where are we?  http://map.datastormusers.com/user1.cfm?user=122
Yahoo Message Number: 87151
"I realize it is subjective, but at what temperature do you (and any others that want to reply) set the hot water temperature alarm?"
Barry
While we don't have an aquarium alarm (yet) I use a regular ice thermnometer mounted the same way.  For me 100 degrees id just about perfect.
Kate
 http://cholulared.blogspot.com &
http://www.cholulared.com
Want to find us? Click below, we're #3096 http://map.datastormusers.com/user1.cfm?user=3096
Yahoo Message Number: 87158
"Doing a Google search seemed to indicate that shower temperatures were in the 110 to 125 degree range. Is this in agreement with your (or any other person's) experience?"
That sounds way too hot to me! I prefer 95-96 degrees F., but I normally run the temperature up to 93-94 degrees and then shut the water heater off, knowing that within a minute or two the thermometer will indicate 95.
