Pad for twin beds November 17, 2007, 08:43:19 am Yahoo Message Number: 86030I have a twin air mattress..the camping type that you blow up with pump. It works great!! I use one for over the cab and the lounge bed. When not in use I deflate them. I purchased one for around 12- 16 dollars at target. It does not have the built in pump. The stand alone pump electric pump was extra but the built in pumps make extra bulk in each mattress. I have had the mattress with one side material and those that are all heavy PVC type. I like the heavy PVC type best, you can get hair and lint off them easier! To inflate just plug in pump to outlet and you have instant beds! Easy Easy, but you do have to put a blanket between you and mattress since the plastic can be cold in winter.Helps my aching back trememdously. Darlene 92 22"FL
