Topic: couple of question (Read 2 times) previous topic - next topic
couple of question
Yahoo Message Number: 85736
Hello All! Just a couple of questions...
1) the spray on stuff that covers the undercarriage and wood storage boxes is starting to wear off our 92 26'MB. Has anyone had to fix this? Or have any ideas?
2)Is the GTG in Santa Paula for Dec. 14, 15, 16 still on?
3.)I spotted a brown LD in Joshua Tree CA on Friday 11/2 about 2:00pm - anyone here? Funny how just seeing another LD makes you smile :)
 Thanks and take care, Pat and Dale
Re: couple of question
Yahoo Message Number: 85756
I'm not sure what the original product is that they put under the chassis, but I can make a recommendation for a great product to re apply.  You can buy Herculiner in gallon cans at lots of different parts stores.  Costco probably has the best deal on it.  It goes on with a roller that comes with the kit.  This stuff is extremely tough.
I actually used it to line the engine compartment of my 69 Bronco and it has held up extremely well under very tough conditions, high heat, brake fluid, gas all sorts of stuff spilling on it.  The best advice I can give you is to make sure your prep work is well done before applying it.  It will adhere to anything but if what you paint it over falls off it will be gone.  I would probably use a wire brush disc on a die grinder or drill and take off as much of the old stuff as possible before applying.  Also take care to keep it off your skin as it is extremely hard to remove.  I would wear a paint smock and full face shield and latex gloves for applying it under a motorhome.  I guarantee if you do a good job of applying Herculiner it will hold up longer than your motorhome.
