Topic: Solar Controller on Sale (Read 6 times) previous topic - next topic
Yahoo Message Number: 85666
Here's a heads-up for anyone thinking of replacing their older solar controller with the new HPV-22B.  AM Solar http://amsolar.com/ has them on sale now for $212.00 (regular price $265.00) and the adapter plate to provide a proper fit in the hole for the RV30S controller that many of us now have is $10.00.  I don't know how long the sale will run.
 I didn't see the sale price on the Web site but it was offered when I called them at 541-726-1091.
Monti
Monument, CO
Re: Solar Controller on Sale
Yahoo Message Number: 85667
Monti,
Thanks for posting that.  It was the incentive I needed to finally replace my old RV-30S.  I should have it in 2-3 days.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 85668
You might also consider the Blue Sky 2000e (formerly RV Power Systems) - - $195 at http://www.mrsolar.com/page/MSOS/CTGY/rv-power. This MPPT is rated 25 amps and I've had good service from mine for the past 8 years. (I previously had it installed in a motorglider, but put a smaller unit in that and transferred the 2000e to Yonder.
bumper
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 85678
"This MPPT is rated 25 amps and I've had good service from mine for the past 8 years. (I previously had it installed in a motorglider, but put a smaller unit in that and transferred the 2000e to Yonder."
bumper
You had a solar powered glider? I'm impressed (but then it's easy to impress me).
Yahoo Message Number: 85687
Larry,
A privilege to join your club, I'm easily impressed too.
 I've owned a motorglider and now a self-launch glider (Schleicher ASH26E). Both are often outfitted with solar panels (factory option). In use, the self-launch maybe runs the engine for 6 to 10 minutes and then shuts down in lift. Follows a multi-hour soaring flight with no engine run. So the solar helps keep the battery up by providing most of the power needed to run all the avionics (soaring computer, Garmin 396 with XM weather and music, etc, etc).
 Since the room for PV panels, which don't go on the wing because of aerodynamic concerns (wing profile is often maintained to within .002") there only room for them on the engine bay doors. Thus a MPPT charge controller is important.
bumper
bumper
"Yonder" '05 MB
Yahoo Message Number: 85696
"Since the room for PV panels, which don't go on the wing because of aerodynamic concerns (wing profile is often maintained to within .002") there only room for them on the engine bay doors. Thus a MPPT charge controller is important."
bumper
 I have been following a company that has a process that prints solar panel on flexible foils. May be the wing coating of the future.
http://www.nanosolar.com/>
Someday we may be able to turn the external shell of our LDs into solar panels.
I sure hope this isn't another one of the 'miracles of the future' that I wasted so much of my youth reading about in Popular Mechanics.
Larry Dreaming about solar-powered flight (or any form of flight that doesn't require going through security)
Yahoo Message Number: 89165
Art
Have you replaced your RV-30S with the new one yet?
 If so, is it an exact replacement if you use the adapter plate or did you have to make additional modifications?  Also is it a simple matter of just moving wires from one unit to the other?
Thanks for your help.
Louis
1999 30' IB
SC 23
Yahoo Message Number: 89277
Art
The HPV-22B has slightly different dimensions than the RV-30S.  As I recall, I had to make the cutout hole a little taller.  I believe I also had to drill at least a couple of screw holes to mount the adapter plate.  Other than the hole modification, it was straightforward.
Art
Art and Barbara
Art's blog
Yahoo Message Number: 89286
I came in late on the solar controller replacement on sale. Can someone clue me in where it is available? I am having trouble accessing the website where the repository is located.
I would like to order a replacement for my RV 30S, and am leaving for a week. Hope they are not all gone!
Steve Chandler, 2001 MB
Yahoo Message Number: 89291
They are at http://www.amsolar.com Current price is $265.00
Monti
Monument, CO
it is available?
