Simple Fix May 18, 2006, 04:01:08 pm Yahoo Message Number: 66865I brought my LD home for a weekend trip after being in storage for about 2 1/2 months. Unfortunately, the refrigerator wouldn't work. I knew others at this site had experienced refigeratior problems in the past and I thought I would have to search the site for possible solutions. On a lark, I used my air compressor and blew air into the burner for the refrigerator. After that, the refrigerator worked perfectly. I also cleaned out the hot water heater burner using the air compressor and it seems to be burning a lot cleaner. If anyone is experiencing problems with the refrigerator or hot water heater after bringing the LD home from storage, you might want to try this first before stressing out.Gary Sowersby 2003 Midbath
Re: [Life With A Lazy Daze RV] Simple Fix Reply #1 – May 18, 2006, 08:30:06 pm Yahoo Message Number: 66871Gary, you might try putting some mothballs in an old pill container with holes in it when you put your LD in storage, in case it was webs or other bug junk. Workes for us. Bob & Verna Getts barby127 no_reply@yahoogroups.com> wrote: I brought my LD home for a weekend trip after being in storage for about 2 1/2 months. Unfortunately, the refrigerator wouldn't work. I knew others at this site had experienced refigeratior problems in the past and I thought I would have to search the site for possible solutions. On a lark, I used my air compressor and blew air into the burner for the refrigerator. After that, the refrigerator worked perfectly. I also cleaned out the hot water heater burner using the air compressor and it seems to be burning a lot cleaner. If anyone is experiencing problems with the refrigerator or hot water heater after bringing the LD home from storage, you might want to try this first before stressing out.Gary Sowersby 2003 MidbathSPONSORED LINKS Recreational vehicles Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators[Non-text portions of this message have been removed]
