Topic: Cruise Control-2005 Ford (Read 7 times) previous topic - next topic
Yahoo Message Number: 66449
I posted the following message and it never appeared in any digest that I subsequently received.  Ross found it somewhere and provided a "compleat" response indicating that he experienced the same performance and had even talked with the Ford folks at FMCA.  I post it again just in case anyone else cares to offer a response.
"I notice that when I have the cruise control engaged on my 2005 30TB Lazy Daze and, with the tow/haul feature off (disengaged), the transmission will downshift in order to keep the speed from increasing on a down hill grade.  This will occur even on the modest descent associated with a freeway overpass. That may sound like normal operation but I don't think any of my automobiles have worked that way.  They always allowed the speed to increase slightly on a downgrade if it could not be held constant in the cruising gear.
When this occurs in my LD, I first experience several for and aft tugs as the unit attemps to hold the speed.  When that is unsuccessful, it downshifts to the next lower gear in order to maintain the speed.
 I can override it by pressing down on the accelerator pedal and that is what I usually do when I think about it before it happens.
Obviously; this is not a major problem but I would like to know if others are having the same experience with their cruise control."
Nate Walker Tacoma
