Topic: cold weather in VA (Read 2 times) previous topic - next topic
cold weather in VA
Yahoo Message Number: 64792
Fern:  One year I spent a sabbatical in Morgantown, WV (WVU) where it gets cold.  Skirted Prowler TT with 3/4in plywood "chipped corners, cracked--etc--i.e. cheap--but sawed-off imperfections" nailed to  2 X 4s at joints/corners. Painted all wood white. Heat taped external water connection and water pipe(s) under TT.  Got 100-250(?) gal propane tank...it was HUGE and left temp setting at 40F during Christmas/Spring breaks (went home to be w/family). Disconnected water hose and left inside TT.  Worked for me.  One problem...couldn't get sta-wgn up the snowy-frozen hills sometimes and had to walk or hitchhike "w/neighbors who had 4 X 4s".
Dec. 05 was in Scotland when temp went to 14F at current home in w/TX. LD un-winterized [i.e. fresh water still in tank) but "no problem".  LD's can take brief cold spells w/out winterizing.  Lucky us.
My wife and I previously worked "VT" (uh...was called VPI then) and lived in Blacksburg.  Go Hokies.
Go girl...you can make it in your LD.
Carroll Carter
Re: [Life With A Lazy Daze RV] cold weather in VA
Yahoo Message Number: 64802
Thanks, Carroll! And thanks for all the good ideas, too.
Carroll Carter wrote:
Fern Horst
Formerly owned:
1979 TK - "Dorie" (2007-2012)
2003 MB - "Absaroka" (2012-2019)
