Topic: CB advice follow up (Read 2 times) previous topic - next topic
CB advice follow up
Yahoo Message Number: 64734
I asked for advice about my CB in msg 64648
When I turn it on it scans the channels.  No matter what I do with the tuning knob, it keeps right on scanning.
And now I can follow up to Art O'Fossil's questions in msg 64650:
First thing is to find out what make and model CB was installed.
It's a Cobra 19 DXIII installed by LD with the '01 coach.  The manual does not mention scanning, so I guess the CB is "out of spec".
I sort-of recollect that it's always been this way (I never got serious about using it).
I was hoping to be a good citizen at the Cheyenne outing
When you come to a Caravan Club gathering, you really need a CB.
but it's not looking good :- John
Re: CB advice follow up
Yahoo Message Number: 64738
I asked for advice about my CB in msg 64648 When I turn it on it scans the channels.  No matter what I do with the tuning knob, it keeps right on scanning............
John
Hi John
 My older CB, long since gone, would "scan" only if the "Up" or "Down" channel buttons were continually depressed. I would wonder if you have an internal short circuit that is making it continually 'scan".  Faced with a similar problem I would probably disconnect it from the power supply, open the case, check visually for any obvious problem, blow out the inside with a can of compressed air, and try it again. If it still wouldn't work, I'd probably replace it.
The last time I had a problem with an electronic device, it was cheaper to buy a new one than pay the shop fee to have the old one repaired. I'm sure the electronic experts in this group can weigh in on this and be of more help.
Will
Yahoo Message Number: 64771
Hi Guys, Yes, when it comes to electronic components nowadays, it's always cheaper to buy and new one rather than having some one mess with the old one.
 Have you unplugged the microphone? Maybe as Will suggested, there might be a problem in the microphone. Stuck "Up and Down keys" are not uncommon. If you don't have a manual to see how to set it up, then you are in deep "kimchie."
If you need to purchase a new one check out the following sites:
http://www.buyreliant.com/ http://www.copper.com/ http://www.bills2way.com/index.html
Regards,
Rubin
Yahoo Message Number: 64788
That's same model as in our '02.  This models doesn't appear to have an intentional scan mode.  But in playing with it, if I hold the channel selection knob 1/2 way between "clicks", IT SCANS through the channels! Sounds like there is a problem with your channel selection knob.  It might well be worth opening up the unit and see if anything is obvious.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: [Life With A Lazy Daze RV] CB advice follow up
Yahoo Message Number: 64797
have you lowered the squelch? If breaking the squelch doesn't stop the scan it's got a problem.
Michelle
jpwoodruff no_reply@yahoogroups.com> wrote: I asked for advice about my CB in msg 64648
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls.  Great rates starting at 1ยข/min.
