Solar panels and an RV cover. March 26, 2006, 07:55:14 pm Yahoo Message Number: 64629I have an '84 22 RB with solar panels installed. The RV is in outstanding contition because it has always been garaged or kept under a cover. [] Obviously, I'd like to continue this, but the cover covers the solar panels. The LED shows the batteries are charging even with the cover on, but how much power am I really likely to generate this way? Enough to keep the batteries topped up if everything nothing is drawing current? [:-/] Has anyone tried cutting out a section of your cover and sewing in a clear or translucent rectangle over your solar panels? [:-?][Non-text portions of this message have been removed]
Re: Solar panels and an RV cover. Reply #1 – March 27, 2006, 10:39:07 pm Yahoo Message Number: 64675marcrwhitaker wrote:The LED shows the batteries are charging even with the cover Quoteon, but how much power am I really likely to generate this way? Enough to keep the batteries topped up if everything nothing is drawing current? [:-/] I too have wondered this [:-/] . Is this tiny trickle charge enough to cover the little current drawn by the propane detector etc.? (0.1 - 0.3 amps)QuoteHas anyone tried cutting out a section of your cover and sewing in a clear or translucent rectangle over your solar panels? [:-?] I thought about it, but in the end didn't bother. We have a 120 plug nearby and just top it off with that now and then. Wish some electrical guru would tell me how often I should do that and for how long? Or if it is even needed?Judy G.Elsie, 23.5 FD[Non-text portions of this message have been removed]
Re: Solar panels and an RV cover. Reply #2 – March 28, 2006, 10:25:59 pm Yahoo Message Number: 64706Judy, When we leave our LD stored for about 6 months every summmer, we leave it plugged
