towing 2005 Honda Accord September 08, 2005, 08:56:36 pm Yahoo Message Number: 57860Help!!! Does anyone know if we can tow a 2005 Honda Accord with the 1996 30ft Lazy Daze? And if you don't where can I find out? Thanks bunches! Lisa
towing 2005 Honda Accord Reply #1 – September 08, 2005, 10:22:25 pm Yahoo Message Number: 57863QuoteHelp!!! Does anyone know if we can tow a 2005 Honda Accord with the 1996 30ft Lazy Daze? And if you don't where can I find out? Thanks bunches! Lisa, what does your Owner's Manual say about if or how it can be towed? The Owner's Manual should always be the place you check first to answer this question. The 2005 Honda Accord is not listed as one of the automobiles which can be towed 4-down in Motorhome Magazine's Dingy Towing Guide -- www.motorhomemagazine.com ; however, that doesn't necessarily mean it can't be towed 4-down, just that Honda hasn't done any towing tests. You might want to check with Remco Towing -- www.remcotowing.com -- to see if there is a modification available that would allow you to tow it 4-down (e.g., drive shaft coupling, lube pump, axle lock). If that fails, then you'll either have to use a tow dolly or put it on a flat bed trailer.Linda Hylton2004 Red 23.5' TKFrom Point Campground/Deschutes NF Cascade Lakes Scenic Byway See where we are: http://map.datastormusers.com/user2.cfm?user=1167
