Older LD info part 2 Longer September 05, 2005, 04:04:29 pm Yahoo Message Number: 57723These are the standard features in 1985Prepared for future microwave, roof rack & ladder Prepared for future 115v roof a/c prepared for future gen set ( except the 18' model) LD designed hi-back cab seats that swivel & recline Cut-out cab-over bed for easier access to driver seat Triple battery system Rear-mounted spare tire integrated within the rear motorhome wallCab a/c 12v roof-mounted evaporative a/c 2 12v oscillating fans Cruise control, tilt steering wheel, dual rear wheels, 1 ton rated chassis Hight torque industrial 350 v8 chevy engine, regular gas 4barrel carb Power disc brakes, power steering, H-D auto trans (th400) Deluxe chassis, including int. & ext. appearance group, gauge, tinted glassTow package, trans cooler, trailer plug, trailer hitch, bumper with rubber insert protector Special designed running boards, retractable coach entry step LD designed front render flares, spoiler air dam am/fm stereo cassette with 4 speakers, fader control Cobra 40 channel CB Winrgard TV antenna(includ. pre-amp) Both truck & coach have sound-deadening insulation installed by LD Double-pane insulated glass in coach, plus ountstanding coach insulation Exterior awning that retracts into metal container & paint to match coach Windshield boot made of heavy vinyl that covers the 3 front windows The exterior of LD coach is custom painted, using paint hardeners 12v center that monitors water, holding tanks, LPG, battery condition H-D convertor with auto battery charger for house battery Refrigerator, forced-air furnace, water heater, all ignite by electronic ignition AES Dometic 3-way refrigerator, with auto swith-over(except 18' model) Laminate safety glass, all fire-retardent interiors, up to 7 emergency exits, fire extinguisher, back-up warning buzzer( any body have this?)Doug
Re: Older LD info part 2 Longer Reply #1 – September 05, 2005, 07:07:57 pm Yahoo Message Number: 57746Quote"These are the standard features in 1985........." Doug: Thanks for the info. I will use it to enrich the "LD changes trhough the years" folder in our files area, which still is an skeleton. It would very interesting to have more similar info about other model years and floorplans, if somebody over there has some to share.ThanksEudoro "archeologist" Lemos, Jr.
