air conditioner August 27, 2005, 04:18:07 pm Yahoo Message Number: 57376Hi There, The air conditioner on my 04 LD is not working. The circuit breaker has never tripped off, but the fan AC will not come on with the generator on or while connected to shore power. Any suggestions before I call Dometic or the LD Factory? The AC is still under warranty. Thanks in advance. Jim B.
air conditioner Reply #1 – August 27, 2005, 04:24:17 pm Yahoo Message Number: 57379Hi There, The AC on my 04 LD is not working. The circuit breaker has never tripped off, but the fan AC will not come on with the generator on or while hooked up to shore power. Any suggestions before I call Dometic or the LD factory? The AC is still under warranty. Thanks in advance. Jim B.
Re: air conditioner Reply #2 – August 28, 2005, 12:36:52 am Yahoo Message Number: 57395You've followed the same troubleshooting path I took
Re: air conditioner Reply #3 – August 28, 2005, 07:57:13 am Yahoo Message Number: 57398-Hello .Wayne here Before dumping the AC, you may want to look for a reset switch on the actual AC. I seem to remember someone on another site recommending this proceedure. That means going up on the roof and taking the cover off. Wayne from Va.
