Paint Help Please August 23, 2005, 10:42:53 pm Yahoo Message Number: 57206I need some help on a Light Grey paint color number for our silver 2001 LD Mid-Bath.The Cardinal Ellis Code #S numbers I received from the mothership are: Light Grey Silver Metallic: 6629-4590 Dark Grey Charcoal Metallic: 6629-7846These codes are for the Imron type paint originally applied to our LD.What I need is the lacquer code for a current paint manufacturer, such as DuPont or PPG, for the Light Grey Silver Metallic. The color I code in DuPont Centari (Enamel) that I was given by another LD owner is B44434, but it turns out to be way too dark to match the light grey on our LD.I have what appears to be a good match for the Dark Grey Charcoal Metallic in lacquer, as PPG code 3223, a 1980 GM /84. The equivalent color in DuPont Centari (Enamel) is B8012.Lacquer works well as touch-up paint for chips. I buy new touchup paint plastic jars of about 4 oz capacity, complete with integral brush and a ball bearing that stirs the paint when shaken, for about $2 at a local auto paint supply. They also have a pressurized air can which has a small empty plastic jar attached that one can fill with lacquer to spray on slightly larger repairs if needed.Can any of you silver grey LD owners help on this?With thanks in advance, Don McG 2001 LD MB
