Topic: Leveler ram lube (Read 3 times) previous topic - next topic
Leveler ram lube
Yahoo Message Number: 56900
Hello,
 Recently installed Bigfoot levelers on our Lazy Daze.  The manufacturer has recommended using a dry lube film on rams to condtion the hydralic seals.  I am finding it difficult to understand what product would work best?  They said it is important to use a product that is NOT litium based or WD-40 (promote dust/dirt collection which would ruin the seals).  Any suggestions are most appreciated!
Sincerely, John Comunelli-Arlington TX '05 MB
Re: Leveler ram lube
Yahoo Message Number: 56901
Hello,
The manufacturer recommended using a dry lube film on the rams to condtion the hydralic seals.  Any suggestions are most appreciated!
I use a silicon lubrucant.  Since I had a can at hand, I use the Lubmaster by Roadmaster.  You can see it at http://www.roadmasterinc.com/lubemaster.html There well may be other, equivalent products out there.
Linley
Yahoo Message Number: 56902
Quote from: john comunelli"
Hello,
Linley
Same here: My installer said any off the shelf silicon spray will do just fine.
I'm currently using the stuff i got at Home Depot.
Ed
