horizon box awning removal 20 years ago Yahoo Message Number: 56452Hi, I need to repair my Horizon Case awning on my 1995 RB and thought it would be easier to do the repairs while on my workbench. I tried removing the screws from the 3 brackets that appears to hold the awning to the side of my LD, but the awning still wouldn't budge. I did a search on previous posts and came up empty handed. Are their additional screws that are only visible when the awning is extended?Mark
Re: horizon box awning removal Reply #1 – 20 years ago Yahoo Message Number: 56459Hi, I need to repair my Horizon Case awning on my 1995 RB and thought it would be easier to do the repairs while on my workbench. I tried removing the screws from the 3 brackets that appears to hold the awning to the side of my LD, but the awning still wouldn't budge. I did a search on previous posts and came up empty handed. Are their additional screws that are only visible when the awning is extended?My Horizon A&E (2004) manual shows only the three brackets, front, middle, and rear, with two screws each mounting the brackets to the coach wall. If no one checks in with better knowledge of this problem, you might call the LD factory for advice, since they installed it. Whenever I've had something stuck and I know that I've gotten all the fasteners, it's almost always been some sort of sealant or adhesive still holding it.Will
