Topic: Our new LD (Read 3 times) previous topic - next topic
Our new LD
Yahoo Message Number: 56027
I just read through the owner's manual for our new LD and notice there is a comment regarding purchasing a jack for the motorhome. Is this true? There is no jack supplied?
Thanks, Cindy
Re: Our new LD - Buy a Jack?
Yahoo Message Number: 56044
there is a comment
Thanks, Cindy
Hello Cindy, You are correct. There is no jack supplied with a new Lazy Daze.
This has been true for many years.  Most, but certainly not all, LD owners do not set up their LD to safely change tire/wheel assemblies.  If you do decide that you need a jack, the LD store sells a good one.  Ours has never been used to change a wheel/tire assy.  I use it only to take the load off the front ball joints when greasing them - about once every three years.
If you do decide to set up your LD so that you can change a wheel/tire assy yourself, you'll need to look into the appropriate aftermarket lug nut torque wrench.  Many of the standard wheel lug nut wrenches will not work effectively on the rear wheel lug nuts because they are recessed in the outside rear wheel 'dish'.  Also, make sure you can manage the weight of the truck wheel/tire assy used on the E450.  There is a lot more to changing a wheel/tire assy on our E450 than on a typical passenger car.........
We have a towing service for unscheduled tire changes - Our RV life does not take us out of contact range with civilization.......
Search the archive message data base and you will find quite a bit of experience and advice on how others have set up themselves for handling unscheduled wheel/tire changes on their LD.
Don McG
Re: Our new LD
Yahoo Message Number: 56062
Cindy,
That's correct, no jack is provided by LD.
Changing the tire on something the weight of the LD is not a negligable task.  I bought a jack (two could be necessary to assure coach clearance), the proper lug wrench, a breaker bar, a torque wench, etc. but hope to never use them.  They are for emergency use only.
jack supplied?
Yahoo Message Number: 56064
 ...is no jack supplied?
Cindy, we have a 2000 LD and it came with a jack and we had to use it recently, had a blow-out on the way home from the Scusset Beach NE LD gathering..didn't want to wait for road service so my husband changed it, no problem...
Lana
