Topic: Refrigerator problems (Read 6 times) previous topic - next topic
Yahoo Message Number: 50842
In regards pilot light going off, and check light coming on, one reason not mentioned so far is dirt/corrosion on the combustion parts at the rear of the frig.  If corrosion is on the burner tubes then the fire will not stay on and the check light inside will then come on.  Hope I am clear...Bang the burner tube going up towards the roof with the palm of your hand and soot should descend.  Then clean the soot and use some sandpaper on the probes at the rear of the frig.  I usually do  this at least once a year and especially when taking the coach out of storage.
When fulltiming this was less of a problem most likely due to the fact that the unit was constantly being used.  Hope that helps.  Quite often RV dealerships will claim that the circuit board ($$$) is bad and that is not the case.  A simple cleaning might be all you need.
2007 RK
