Topic: overfilling the propane tank (Read 13 times) previous topic - next topic
Yahoo Message Number: 49989
Hi gang, I have a question that some of you "very experienced RVers" might be able to help with. I meant to ask this last fall, and I checked the "searchable message" section to no avail. Also just finished reading on another site about someone who had this problem.
The issue is over filling of the propane tank. I was under the impression that these newer tanks had some sort of overfill protection device that made it impossible to overfill the propane tank. Perhaps "impossible" is the wrong word to use, but I thought it was something unlikely to happen. Last fall, we stopped at a Flying J and bought propane. I watched the attendant fill someone's portable tank and suspected he was fairly inexperienced. After leaving the Flying J, we stopped at a rest area and I decided to check the gauge on the tank; the needle was pointing very close to the full mark, rather than the usual 75% mark like it normally would after filling.
Possibly the attendant overfilled my tank, what should  or could I have done?
On the Born Free owner's site, someone just had the same problem.
They made the comment that the person who filled their tank seemed like they had never done that before and said "Phew, sure glad that job is overwith" when finishing. That was their clue they had a problem. They ended up smelling propane and went somewhere to have the pressure released a couple days later.
Apparently overfilling is possible or do I have a problem with my tanks overfill protection device(s)? What can the owner do to safely relieve pressure if they discover they have an overfilled tank?
Thanks, Steve K.
Steve K
2003 Mid-bath
Re: overfilling the propane tank
Yahoo Message Number: 49998
nukamper2000  wrote:
"The issue is over filling of the propane tank. I was under the impression that these newer tanks had some sort of overfill protection device that made it impossible to overfill the propane tank. Perhaps "impossible" is the wrong word to use, but I thought it was something unlikely to happen."
Steve, the OPD is *supposed* to be idiot-proof and prevent overfilling of the propane tank; when the tank reaches about 80% capacity, the OPD should prevent entry of any more LPG into the tank.  It's possible that the OPD on the tank in question is defective: these web site references provide the particulars:
 http://manchestertank.com/safety/scg_valves.htm
http://manchestertank.com/safety/opd.htm
 http://www.scgmiyairi.com/wst_page5.html
I put your question to a very experienced RV tech and "gas guru" who runs the RV tech program at a trade school in BC; he's out of the office until Monday, but when he replies, I'll post his answer.
Many RVers feel differently about this, I understand, but IMO, filling up with propane is best done at a propane supplier's outlet; the chances of getting an untrained, unskilled, and careless person is much less at a propane supplier's than at a campground or a gas station.  (I've seen some pretty scary things at each of these locations!)   Here are web sites for locations of major propane suppliers:
www.suburbanpropane.com/consumer/locator/index.html
www.amerigas.com/locationfinder_Retail.html
www.ferrellgas.com/CompanyDirectory.asp
You might also google "OPD" and "LPG" for more information.
Yahoo Message Number: 50001
outlet;  the chances of getting an untrained, unskilled, and careless person > is much less at a propane supplier's than at a campground or a gas
Hi Joan, thanks for researching for me. I will have to check those resources, but I will be curious as to the reply you get from your expert.
I figured, (assumed, don't you hate that word) that a volume place like Flying J would know what they are doing and would have well trained attendants. I thought maybe it was a fluke occurance, but after reading the BF owners plight and also that of someone else on this board who had a problem with propane fill up on his way home from picking up the LD; it may be more common than thought.
Thanks again, Steve K
Steve K
2003 Mid-bath
Yahoo Message Number: 50009
It should not be possible to overfill an OPD-equipped tank. I suspect many operators simply stop filling at the first sign of vapor in the pressure release valve. This wastes less fuel and causes less polution in a notoriously environmentally 'dirty' process. The result might be a less than optimally filled tank, though. The 'full' indicator would hopefully be set for max allowable for the tank - not brim-full.
Yahoo Message Number: 50012
Steve and others
 The "full" mark on the propane tank gage indeed reads on the amount of chargeable liquid - it reads "full" when the tank is physically 80% full.
Gus Weber
Yahoo Message Number: 50014
full.
I got those same words from Steve at the factory and, if memory serves, people have reported 100% readings when filled to the vent.
However, our propane tank's gauge apparently is in error.  It reads about 75% when the tank has been filled to the vent.  I decided to live with it instead of trying to get it fixed with unknown results.
From what I have read on this site, there apparently are more tanks like mine out there.  I haven't read of any that read more than 100% when full to the vent, though.
Linley
Yahoo Message Number: 50015
full.
I don't find the gauge on our tank to be very accurate.  It never seems to read full and seems to hold 2-3 gallons when the gauge is nearing "E".  I know it is getting filled, because you can hear the pump on the filling tank start to strain when the OPD float valve closes (could be the valve closing too soon).
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Yahoo Message Number: 50022
wrote: The "full" mark on the propane tank gage indeed reads on the amount of chargeable liquid - it reads "full" when the tank is physically 80% full.
"lfgcfg"  wrote: I got those same words from Steve at the factory and, if memory serves, people have reported 100% readings when filled to the vent.
However, our propane tank's gauge apparently is in error.  It reads about 75% when the tank has been filled to the vent.... From what I have read on this site, there apparently are more tanks like mine out there.
My gauge reads "3/4" when the tank is filled to 75%-80%; I have never seen it read "Full".  I keep wishing for gauges and readouts which show the *number of gallons* of fuel, grey and black tank content, and propane in the tanks instead of fractions and the unknown territory between them.
Yahoo Message Number: 50031
Joan:
 The problem with filling the tanks is that the tell tale valve which releases liquid when the tank is 80% full, is not used properly.  As soon as a little liquid comes out, most operators shut off the propane, leaving the tank less than 80% full.  Once, I was able to convince an operator to fill until the cutoff occurred, and by that time the tell tale valve was no longer intermittantly letting off gas, but was nearly steady liquid.  I then realized most tank refills were less than 80%.
Gus Weber
Yahoo Message Number: 50050
Our inside propane "gauge" reads full most of the time.  Even now at night when the outside gauge read somewhat more than 1/4 full.
best,  paul
Yahoo Message Number: 50086
best,  paul
Hi (best)Paul! Are you saying that all the lights are lit up when your tank is 1/4 full? I seem to remember that someone, I'm not saying it was you though, was reading their monitor incorrectly, thinking if the lights were off the tanks were full.
Regarding overfilling the propane, I am now even more confused by what the gauge on the tank should read when the tank is full. I am pretty sure it should never read full on the gauge, but .....? I've had my tank filled about 5 times previously, to the point where all the lights on the monitor were lit up, but they tank gauge never read more than a little over the 75% mark. Until this last fill up which I am questioning.
Hope we get some authoritative answer from JC's expert.
Steve K.
Steve K
2003 Mid-bath
Yahoo Message Number: 50125
Yup.  Although I have seen the inside display at 2/3 recently.  I suspect it might be related to temperature.
Yup.  Something like that was me (about water tanks).  Not on propane.
As I read the propane inside display all 4 lights lit means a full tank.  All 4 lights on my inside propane display are lit.  Outside says somewhat more than 1/4 full.  Not close. No cigar. No baseball cap.
Here in San Felipe it's not much of a problem since we use so little propane (even with baking over holidays).  We "filled up" with propane here in San Felipe Oct 15 or so - 3.5 months ago - and still have 1/4+ tank left.  We'll probably fill up here when we leave at the end of Feb (after the San Felipe 250).  With baking I did see the outside tank drop from 3/8+ full to 1/4+ full.  So I know the outside gauge is working.  How accurate?  Who knows?
best,  paul
Yahoo Message Number: 50225
Steve, the OPD is *supposed* to be idiot-proof and prevent overfilling of the propane tank; when the tank reaches about 80% capacity, the OPD should prevent entry of any more LPG into the tank.  It's possible that the OPD on the tank in question is defective: I put your question to a very experienced RV tech and "gas guru"
Joan, did you get a reply from your friend the RV "gas guru"? I'm curious as to what a trained expert has to say about this. Thanks.
Steve K.
Steve K
2003 Mid-bath
Yahoo Message Number: 50227
nukamper2000  wrote: Joan, did you get a reply from your friend the RV "gas guru"? I'm curious as to what a trained expert has to say about this. Thanks.
No, he hasn't replied yet.  I sent an "addendum" about purging, too.  If I don't hear from him in a day or so, I'll email again.
I'll post when he replies.
Yahoo Message Number: 50229
Thanks again JC. I'll appreciate any info you receive.
Steve K.
Steve K
2003 Mid-bath
