Mid-Bath Accordion Door February 17, 2024, 12:24:28 am Removed the accordion door that separates the rear lounge and the rest of the coach, as we’ve never used it and it just got in the way. I reinstalled the mounting screws and put the white plastic caps back on, which looks better than a bunch of holes. But now the TV mounting bolts are exposed. Short of building a pantry (which I may do someday), any suggestions for hiding the TV mounting bolts?
Re: Mid-Bath Accordion Door Reply #1 – February 17, 2024, 12:37:32 am Gregg,Perhaps something as simple as a cover like this one on Amazon. Not sure of the fit for your particular assembly (nut) but there may be other sizes available.(4-Pack) Spring Steel Push On Pushnut Caps with Mechanical Zinc Plating -...Good luck.Kent 1 Likes As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Mid-Bath Accordion Door Reply #2 – February 17, 2024, 09:35:15 am Quote from: HiLola - February 17, 2024, 12:24:28 amBut now the TV mounting bolts are exposed. Short of building a pantry (which I may do someday), any suggestions for hiding the TV mounting bolts?LD reversed your mounting bolts with the nuts on the TV bracket side. To keep a low profile they used carriage bolts and fender washers and then painted both with a wall matching paint. Kendall 1 Likes
Re: Mid-Bath Accordion Door Reply #3 – February 17, 2024, 09:45:44 am Paint them a color that blends in with your wood color.Adding anything else just attracts attention to the area where the bolts are that you’re trying to hide. 1 Likes
Re: Mid-Bath Accordion Door Reply #4 – February 17, 2024, 10:29:41 am Quote from: RIMRIDER - February 17, 2024, 09:35:15 amLD reversed your mounting bolts with the nuts on the TV bracket side. To keep a low profile they used carriage bolts and fender washers and then painted both with a wall matching paint.Interesting!
Re: Mid-Bath Accordion Door Reply #5 – February 17, 2024, 11:55:52 am Nut and bolt caps are available in several sizes, similar to the caps that cover toilet mounting boltsBed Bath & Beyond | The Best Deals Online: Furniture, Bedding, Rugs, Kitchen...Paint the caps the color of your choiceUsing carriage bolts, as mentioned, would be another good way of disguising them.Larry
