Topic: Haze on rear window (Read 357 times) previous topic - next topic
Haze on rear window
Preparing my LD for storage. I noticed this haze on my rear window. It appears to be on the inside of the outside glass.
When I purchased my Lazy Daze the rear window at some point and been broken and replaced with a piece of tinted Lexan.
about three or four years ago I purchased a new window with frame from the mothership before they closed. It was installed by Camping world.
Any ideas what could be causing the hazing? Hopefully not moisture.
Thanks!
Mark     https://www.lazydazeowners.com/index.php?topic=39141.msg253397;topicseen#gallery_253397
2002 30' IB
Re: Haze on rear window
Hello Mark,
From looking at the photo that was in the post earlier, it looks like a “fogged” window.  As you probably know, fogged windows are caused when the seal between the 2 panes leak allowing in moisture.  Common on most if not all RVs with this type of windows.  Unfortunately, it’s a yuck kind of issue.
Can this be corrected? If so how? I've read the window needs to be removed, taken apart and resealed?
I'm maybe selling my LD come spring. I really don't want to spend a ton of money to correct this.
Thanks!
Mark
2002 30' IB
The windows can be taken apart, cleaned, and resealed, it's hard to find a shop that willing to do this
You have been lucky that it has taken so long for this to happen, our 2003's windows started to fog
several years ago.
This is moisture trapped between the panes not your typical fogging.
Like I mentioned. The owner I purchased it from had apparently  broken the original window.
I didn't notice until I was washing the rig and noticed this was not glass but very dark Lexan.
I purchased a new window and frame from the mothership. It was installed by Camping World.
This is the first time this moisture has appeared.
2002 30' IB
Attached are photos of the moisture between the two window panes.
You'll notice how the moisture moves from the right to the left.
2002 30' IB
Moisture between the frames IS the fogging.
The window is made of 2 panes of glass with a seal between them.   When the seal is in good shape, the dry gas trapped between the panes has no moisture.
When the seal breaks, moist air can enter the space between the 2 panes.   When that air cools, the moisture condenses.
Most of my windows have some degree of fogging.   I'd like to get it fixed, but I haven't found a great local solution that I am confident about.
I know you don't want to spend a whole lot more, but here is what our member Craig P did with his rig, just about a year ago.  I liked it well enough that I may go that way if I ever need to. Hard way to fix a Rear Window Leak
  Both his rig and mine are are E350's and 6" narrower than your E450. I don't know if your window is wider than ours but I liked him removing those little side windows.  I have hit the little window with my toes using the ladder, so maybe Lazy Daze put those small windows in so that in case just the small one got damaged, it could be replaced easier.
RonB
Hi Ron.
My rear window is one large window not three panels.
2002 30' IB
Hi Mark; Sorry, I was thinking large window across the entire back.  So your IB has smaller windows and they will cost less to replace.    You can see the separate panes on Craig P's rear window that he broke.   Hard way to fix a Rear Window Leak  You might still try his vendor. That company might have better windows than the ones Lazy Daze were getting. Can't say that those windows have a very good track record so far.   RonB
Hi Ron-
I should clarify. My LD is a 31' IB. It has the large rear window.
When I purchased my LD I did not notice the rear window had been replaced with dark tinted Lexan.
Apparently the previous owner had damaged or broken the original window.
I ordered a new window with frame from the mothership. The window is only 4 or 5 years old. It was installed by Camping World.
It was not cheap to replace the window. If I decide to sell it I will not replace it again.
2002 30' IB
You used Camping World!
I was in Northern Minnesota. There was very few rv shops nearby.
2002 30' IB
Hi Mark.  My copies of the 31' island bed:  https://www.lazydazeowners.com/MGalleryItem.php?id=3468  show a smaller window.  So the larger window, as shown on the twin bed configuration, would be more expensive.
     The comment about Camping World; I've had bad luck with the one in my area. I have been assured though that each individual store is dependent on the management of that store and it isn't company wide. The one here moved from El Cajon to San Marcos. Both about equidistant. But has now moved to Temecula into Riverside county. Much farther away.      RonB
"I have been assured though that each individual store is dependent on the management of that store and it isn't company wide."
Essentially a true statement... some are good, some not so good. I've had good work done here and not so good over there!   ::)
And I would add that even within a given Camping World store, results can vary widely from department to department, and even within a department.
Take the store in Bridgeport, NJ. Back in the Nineties, their front desk went way out of their way to be helpful with a large purchase I made. And their service department did an excellent job of installing a new stove in my 1985 Twin/King, did it in just two hours despite the need for carpentry to make it fit, and did it at a bargain price.
On the other hand, their service department also twice screwed up my rig's plumbing when winterizing, resulting in disastrous leakage and flooding each time. Likewise, back in 2012 the Camping World service department in Albuquerque took two days to install that same model stove in my 2003 Midbath, did a lousy job of it, and tried to grossly overcharge me.*
Given that Camping World's prices are almost always higher than anybody else's, their service is not reliable, and they keep hard-selling various club memberships, I won't go there unless--as in Nadaze's case--there really is no alternative.
* As I recall, they used less than six feet of 1x4 oak, but billed me for eight feet of 1x12!
