Converter Fan 4655 September 24, 2023, 07:21:42 pm I just replaced the converter with the PD4655 to support lithium batteries. I still have the wet cells installed. The wet cells are charged. Anyhow, with all the 12 volt stuff running, the converter is charging the battery bank at 13.65v but the converter fan is not running. Is this normal? Thanks. jor
Re: Converter Fan 4655 Reply #1 – September 24, 2023, 07:39:27 pm Yes, the PD converters only run the fan when it is getting too warm. Nice bonus....
Re: Converter Fan 4655 Reply #2 – September 25, 2023, 08:14:38 pm Quote from: jor - September 24, 2023, 07:21:42 pmI just replaced the converter with the PD4655 to support lithium batteries. I still have the wet cells installed. The wet cells are charged. Anyhow, with all the 12 volt stuff running, the converter is charging the battery bank at 13.65v but the converter fan is not running. Is this normal? Thanks. jor At 13.65V your batteries are fully charged, and the converter is running float mode. If you press the button to force bulk charge, fully charged flooded cell will also not cause the fan to trip on. With LFP batteries it will be a different story. With the batteries discharged by even just 10% they will draw a lot of current and likely turn on the fan for awhile...Steve
Re: Converter Fan 4655 Reply #3 – September 25, 2023, 09:07:58 pm Quote from: Steve - September 25, 2023, 08:14:38 pmWith the batteries discharged by even just 10%, they will draw a lot of current and likely turn on the fan for a while...Our 200-amp/hour lithium battery will pull 50-amps until nearly fully charged with the PD 9270 converter The converter's fan will definitely be running if the converter runs for more than 15 minutes. One advantage of lithium batteries is their ability to more efficiently use solar charging and short charging periods when using the converter, which is rare. Normally our LD's converter circuit breaker is turned off, letting the batteries charge exclusively on solar.Larry
