Topic: 2016 MB upper rear clearance lights (Read 311 times) previous topic - next topic
Hi Folks,
I have one of the five rear upper red  clearance lights very dim. Mine are LED style, yet the motorhome owners manual claims they are 193/194 bulbs which is not right. I will need to replace the whole (tiny) light assembly to fix it as it all bonded together. A search of the forum doesn’t yield any help. Anyone run into this issue and have a part number to replace?
Thanks
Karl
2016 Mid Bath
Re: 2016 MB upper rear clearance lights
Hello
I did replace one of my front running lights.  I am not sure but I think I ordered it from E Trailer.
You should be able to search with the information on the photo attached.
Cheers!
Tony R. (aka codefour)
Tony R
Here is a pic of my clearance lights.
2016 Mid Bath
I'll recommend Todd Miller as a source of factory correct parts.  New enough that they should be obtainable still from the manufacturer or from Todd.   RonB
Update!  E-trailer to the rescue. It’s a peterson 194R, they also have the chrome bezel. They have both the red and the amber (194A) for the front.
2016 Mid Bath
Also discovered one of my front amber clearance light had one of the LEDs out. Much more difficult to pull the wiring out far enough to crimp on the new light assy.
On the rear, I could pull the wiring and butt connectors out far enough to cut and splice on the new pigtails.
Hats off the LD for flooding the holes behind the lights with copious amounts of caulk.  No leaks possible.
Notice the clothes pins to prevent the wires from slipping back into the hole and disappearing forever.
2016 Mid Bath
When replacing the stock incandescent tail lights, it's a necessity to clamp the wires with hemostats before cutting old old tail lights free.  The first time I changed a set of tail lights to LEDs, I learned the hard way and watched the wires disappear forever into the back wall. A couple of hours later, a new set of wires had been snaked into position. Live and learn.
This thread brings to mind the situation when you have just a small length of wire available and can't get a good crimp. I've never used these solder seal connectors myself but I'm going to get some. Should take the stress out of the "I've only got one chance at this" situations. no-crimp connectors
09 27' MB
10  Suby Forester
