Topic: Generator maintenance with no batteries  (Read 218 times) previous topic - next topic
2008 MB winterized and put in storage (away from home), new batteries on trickle chargers in garage, how can I do my monthly generator run? Pretty new to this all advice much appreciated!
TYIA 😁
2008 27' Mid Bath
Re: Generator maintenance with no batteries
Hi KMK20;  You don't say where your MB is located, but if it is cold enough, you should just let the generator sit until springtime.   RonB
Drain the float bowl.
Harry 2006RB
Thank you, Ron B. I am just outside of Nashville, TN.
2008 27' Mid Bath
Have you put stabilizer (Sta-Bil) in the tank and run the generator before you stored it? That should keep the carb from gumming up. If not, I recommend you pop the batteries back in to do this - a pain, but better than the expense of a new carb and service call...
Thank you, Steve. That was not done, but I will certainly look into it!
2008 27' Mid Bath
