Black tank replacement June 28, 2021, 01:34:45 pm I had the front bracket on my 97 MB black tank come loose while I was driving dropping it to the ground and wearing a hole in the front of it. I called Todd at the mothership to get a new one but he told me they no longer carry them. The 97 is a different size to the new ones. He told me that the size is a 30-H. I tried finding on line using this number but don't seem to be able to find one.Just seeing if anyone has had any experience replacing the black tank on a 97 MB. Haven't been able to get under the rig to measure the old one yet as I am not at home for the next couple of days.
Re: Black tank replacement Reply #1 – June 28, 2021, 02:14:23 pm How big is the hole? Could it be patched with Eternabond tape, or more permanently with welded-on plastic material of the same type?
Re: Black tank replacement Reply #2 – June 28, 2021, 03:01:51 pm Quote from: Andy Baird - June 28, 2021, 02:14:23 pmHow big is the hole? Could it be patched with Eternabond tape, or more permanently with welded-on plastic material of the same type?Plastic fabrication shops can hot-air weld patches on a damaged tank. Some RV shops can repair tanks too.Might even be a DIY project.1600W Heating Gun Hot Air Gun PVC TPO Plastic welding gun (Type D) - -...Steinel Heat Gun - How To Plastic Weld - Plastic Welding Toolhttps://www.harborfreight.com/plastic-welding-kit-with-air-motor-and-temperature-adjustment-96712.htmlLarry As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Black tank replacement Reply #3 – June 28, 2021, 03:11:46 pm Quote from: Larry W - June 28, 2021, 03:01:51 pmPlastic fabrication shops can hot-air weld patches on a damaged tank. Some RV shops can repair tanks too.Might even be a DIY project.1600W Heating Gun Hot Air Gun PVC TPO Plastic welding gun (Type D) - -...Steinel Heat Gun - How To Plastic Weld - Plastic Welding Toolhttps://www.harborfreight.com/plastic-welding-kit-with-air-motor-and-temperature-adjustment-96712.htmlLarryMany thanks for the reply. I'm not at home for the next couple of days. I'll check it out when I get home. As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Black tank replacement Reply #4 – June 28, 2021, 06:19:26 pm They are out there. I can't say if it's the same.22 Gallon Rv Holding Tank R-30H | Plastic-MartRich
Re: Black tank replacement Reply #5 – June 28, 2021, 06:29:37 pm Quote from: rich - June 28, 2021, 06:19:26 pmThey are out there. I can't say if it's the same.22 Gallon Rv Holding Tank R-30H | Plastic-MartIf it is the same size, the inlet is still needed, the site states they will install any size fitting in any location. This may be a good resource to remember, tanks often get damaged.Larry 1 Likes
