Re: Recommendations - Windshield Cover Reply #26 – June 27, 2019, 10:44:51 am The only time we used the external cover was when the LD was parked between trips. In fact, we never even bothered to take it with us when on the road. At night we just closed the interior cab curtain for privacy. During the day Puddy-Tat loved stretching out on the dash, belly to the sun.
Re: Recommendations - Windshield Cover Reply #27 – June 12, 2021, 04:10:23 pm Anyone use one of these?Amazon.com: BougeRV RV Windshield Window Snow Cover for Class C Ford...Looking for one that offers insulation.Thanks,Steve As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Recommendations - Windshield Cover Reply #28 – June 12, 2021, 04:29:42 pm Thanks Steve for mentioning these. I don't spend time in the snow, but I find my cover useful in sunlight when the A/C is running. The comment about ensuring privacy doesn't hold true with the magnet being all that holds down the corners. RonB 1 Likes
Re: Recommendations - Windshield Cover Reply #29 – June 12, 2021, 04:44:29 pm I have an older cover for the 2002 24ft TK. It is not insulated so I slide reflectix between the windshield and cover. The cover hasthe loop at the top to slip onto the door. The bottom two edges have a metal button like hole The LD door has a fastener that slips through the hole to secure the bottom edges.It is a very tight fit. Also have sttaps that velcro around both mirrors.
Re: Recommendations - Windshield Cover Reply #30 – June 12, 2021, 07:08:30 pm I have the factory included vinyl cover as well and used it last winter. We are full timers. The vinyl certainty helped in freezing temps but I like the idea of an insulated one for next winter. I’m thinking it will help in hot weather too.I’ve thought of using insulation between the vinyl cover and windshield but the factory vinyl cover fits so dang tight I didn’t want to go that route.
Re: Recommendations - Windshield Cover Reply #31 – June 12, 2021, 07:53:09 pm We have the factory included vinyl cover also and have used it a few times. Didn't care for the mess and hassle getting it on and off and stored. And what do you do with hang tabs, site assignment slips, etc,? We now have this set FORD E-SERIES VAN & MOTORHOME SUNSHADE and like it.Charles
Re: Recommendations - Windshield Cover Reply #32 – June 12, 2021, 08:51:04 pm I got this one:I like having the side windows free.http://www.etrailer.com/Covers/etrailer/e98899.html?feed=npn&utm_source=google&utm_medium=cpc&utm_campaign=Google%20%7C%20Shop%20-%20Low%20Volume%20-%201900&adgroupid=122586045740&campaignid=10268224741&creative=519192903740&device=m&devicemodel=&feeditemid=&keyword=&loc_interest_ms=&loc_physical_ms=9033035&matchtype=&network=g&placement=&position=&gclid=CjwKCAjwtpGGBhBJEiwAyRZX2m8k2cml55XLA7dpFlzN8nJ4C1wHI5wMu8Cf6kGw2MpnZ69PUusW_xoCdUcQAvD_BwE
Re: Recommendations - Windshield Cover Reply #33 – June 12, 2021, 10:24:30 pm SteveWe bought that one for our 2021 MB. It is OK has straps that go over the top corner of the door Velcro around the mirrors and magnets on the lower door corner. The insulation appears to have some value and I suspect we will appreciate even more in hot weather. So far our only use is storage at home and a month working our way up the Oregon coast. Todd tried to talk me into one of their covers which I gather attach with screws. I did not want to worry about potential corrosion around the snaps and declined. After putting this on and off a number of times I can understand why they use snaps. Our last RV was a Winnebago Aspect which had a small overhang and putting on the cover was a piece of cake. On the LD with its large cab over and tight clearance not so easy. I now leave one of the cab windows down to make it easier to work the strap over the corner. I think that anyone the vinyl covers will have the same problem. Good luck.Ken
Re: Recommendations - Windshield Cover Reply #34 – June 13, 2021, 08:17:08 am We bought one from Amazon last year when I knew we was going camping in the summer if Florida, it also is now unavailable. We have used it a few times. We go camping once a month, probably use it 20% of the time. I used it when it is really hot and not so many trees. This time of year I will be using it again along with the reflectux in the vents and skylight. When we don't use it I just use the curtains for privacy. During the day sometimes I may open the curtains to see out the front. I would buy it again.
Re: Recommendations - Windshield Cover Reply #35 – June 13, 2021, 09:12:03 am We use the custom fit vinyl exterior cover purchased from the factory then inside we use the custom fit windshield and side windows reflectors from HeatShield. Then, like many, we hang a blanket across the cab opening to reduce heat/cold.For camp reservation tags or anything else that needs to be seen from the outside, we use "painter's blue tape" to attach them to the vinyl cover.Works great for us and allows us to utilize the cab area as additional "living space" as we keep a cooler in there that we go into occasionally.Bill 1 Likes
Re: Recommendations - Windshield Cover Reply #36 – June 13, 2021, 01:18:09 pm Quote from: KJWarner - June 12, 2021, 10:24:30 pmSteveWe bought that one for our 2021 MB. It is OK has straps that go over the top corner of the door Velcro around the mirrors and magnets on the lower door corner. The insulation appears to have some value and I suspect we will appreciate even more in hot weather. So far our only use is storage at home and a month working our way up the Oregon coast. Todd tried to talk me into one of their covers which I gather attach with screws. I did not want to worry about potential corrosion around the snaps and declined. After putting this on and off a number of times I can understand why they use snaps. Our last RV was a Winnebago Aspect which had a small overhang and putting on the cover was a piece of cake. On the LD with its large cab over and tight clearance not so easy. I now leave one of the cab windows down to make it easier to work the strap over the corner. I think that anyone the vinyl covers will have the same problem. Good luck.KenOn my 1995TK I had a cover that used magnets.Keep an eye out for potential paint scratches where the magnet makes contact over time.
Re: Recommendations - Windshield Cover Reply #37 – June 13, 2021, 01:24:21 pm Quote from: tedeboy - June 13, 2021, 01:18:09 pmOn my 1995TK I had a cover that used magnets.Keep an eye out for potential paint scratches where the magnet makes contact over time. No magnets on ours.....I'd be concerned for that exact reason especially in some of the winds we've experienced!
Re: Recommendations - Windshield Cover Reply #38 – June 13, 2021, 02:07:30 pm Quote from: pdl2win - June 13, 2021, 01:24:21 pmNo magnets on ours.....I'd be concerned for that exact reason especially in some of the winds we've experienced!Yes. Especially a wind storm with sand involved. 1 Likes
Re: Recommendations - Windshield Cover Reply #39 – June 13, 2021, 05:38:21 pm Ordered the Bouge cover yesterday and it arrived today (that was quick!). Fits nice and loose compared to the factory vinyl. This winter I’ll sandwich the vinyl one between the Bouge and windshield for extra insulation. I like the idea of putting exposure wear on the cheaper Bougman.It hooks over the upper corners of the doors and uses magnets on the bottom corners. I’ll keep an eye on wear to avoid scratches.Interior shields have their advantages but won’t have the highest insulation factor.
Re: Recommendations - Windshield Cover Reply #40 – June 13, 2021, 06:52:36 pm When installing windshield covers with magnetic corners, cut pieces of clear, surface protection tape, applying the tape where the magnets will sit, it will keep them from scratching the paint.The tape is a 3M product made for exterior usage on vehcles..Amazon.com: 3M Clear Paint Protection Bulk Film Roll 6-by-25-inches: AutomotiveAmazon.com: VViViD 3M Clear Paint Protection Vinyl Film 6 Inch Wide Choose...Larry As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
