Topic: Non-member Classified Listings for 2021 (Read 15902 times) previous topic - next topic - Topic derived from Non-member Classifie...
Re: Non-member Classified Listings for 2021
Reply #225
Hi Romeo;  "What are the "Boils" in the aluminum above"  under and around the cabover passenger side window...  That is caused by water penetration behind the aluminum.  Called 'electrolysis' an electric current through the water dissolves the aluminum. Aluminum chloride mostly.  By the time the corrosion comes out under the paint, a larger amount of aluminum is 'crumbly' . Time consuming to fix; the water leak has to be fixed first from the inside, then restoration of the aluminum, think Bondo, then paint.
    If you are retired with a lot of time, and a skill set for 'inside the wall' repairs of rot, it would make a good 'project' motorhome. If you have to pay someone else to fix it, then 'prohibitively expensive' would apply.  RonB
Yeah, Not something I would take on.  Interesting to know how that damage to aluminum happens.  Common thought would be that aluminum never corrodes like on a car.  Obviously not.  Good infromation.
Long time Lazy Daze fan. I'm finally about to be able to buy my first.  Looking for a 23.5 front lounge. If you are in the St. Louis area and are willing to give me a tour of yours, no matter what the size, even if it's not for sale, please contact me.
Reply #226
Here's one been for sale for awhile.  Thought I had posted it before.
26 1991 $13K Lazy Daze REAR BATH La Mesa CA
Redirecting...
Looks just like mine except mine is in better shape and only 50k miles.  Same interior. I wonder what happened to the rear bumper.
SoCal-Gal  (Tracy)
1991 26.5 RB
Previous 1992 Six-pack Camper
Reply #227
Missing the ladder and roof rack also.    RonB
Reply #228
Corrosion can be caused by several things. Poor surface preparation before painting is one.
Another cause seen is is corrsion cause by the interaction of a steel fastener (nail, screw or staple and the outer aluminum sheet metal, cause by either direct contact or being located in an area that has been wet…good, old fashion corrosion.
The dissimilar metals, with a little moisture, become batteries and start consumming the aluminum.
Our 1983 LD had a couple of bubbles in the aluminum, when the corrosion was removed, steel staples were found directly under
both spots. This should be considered a design or manufacturing defect. The two dissimilar metals should have never had a chance of touching.
Reply #229
Here's a beauty for what I see as a reasonable price. As says he's an RV tech.
26 2003 $31K Lazy Daze REAR BATH Julian CA 6/21
https://www.rvtrader.com/listing/2003-Lazy-Daze-26.5-REAR-BATH-5016716135
Details from Seller
2003 Lazy Daze 26.5 RB
Full Title
CA Smog certified
Ford E-450 fuel injected V-10
96,070 miles
2 sofas convertible twin to king bed
Cab-over queen bed w/ladder
Full rear bath w/shower, porcelain toilet & wardrobe
Dometic Royale LP/Elec freezer/refrigerator
Suburban LP furnace
Dometic DuoTherm low profile air conditioner
Atwood DSI LP water heater
Dometic 1100 watt microwave
Atwood 3-burner stove/oven
Onan 4kw generator
Outside auxiliary shower
2 Fantastic Fan vents,1 with rain sensor auto close
1 standard ceiling vent
1 escape hatch/vent
Fresh Water 50 gals
Black water holding tank capacity 30 gals
Grey water holding tank capacity 30 gals
55 gal 87 octane fuel tank
FM/AM/CD player with stereo ceiling speakers
12v 17” flatscreen TV with Aux Video input for DVD or USB
Digital TV antenna with amplifier
30 amp service
2 Interstate 6v deep cycle house batteries
1 Interstate vehicle starter battery
Firestone dual rear and front tires & spare tire
Original Owner’s Manual
Repair and maintenance invoice/receipts
I am a certified RV repair tech and have taken a lot of pride in owning and maintaining this classic Lazy Daze. For serious buyers who know the reputation of Lazy Daze as the premier Class C motorhome.
This classic RV is well equipped and ready for the serious traveler.
Reply #230
It’s mighty nice that some of our LD Neighbors post information about LDs that are for sale from all manner of sources.   In addition, the keen observations about various pros and cons has to be useful to less experienced Searchers.
It’s certainly a kind service that must be helpful to those in the Search Mode.  So thanks to those On-Line Helpers.
Reply #231
The rig shows as "clean", but the seller might want to correct the GVWR, listed as 14500 pounds, to the correct GVWR of 14050 pounds. (And include photos of the roof, tire age and condition information, etc.)
Reply #232
The ‘03 RB in Julian looks pretty clean!
Reply #233
Original owner-- That's refreshing....
30 1998 $29K Lazy Daze REAR QUEEN, Littleton CO 6/21
https://www.rvtrader.com/listing/1998-Lazy-Daze-30-REAR-QUEEN-5016741719
Details from Seller
Additional features:
* Banks Exhaust System
* Brake Buddy System
* New microwave
* New kitchen faucet
* New awning
* Like-new tires (2400 miles)
Other information:
* Miles are mostly highway
* Meticulously maintained and great overall condition
* Original owner
    Condition: Used
    Year: 1998
    Make: Lazy Daze
    Model: 30 REAR QUEEN
    Class: Class C
    Mileage: 110,729
    Fuel Type: GAS
    Gross Vehicle Weight: 14,050-lb
    Engine Type: 6.8L Triton V10
    Sleeping Capacity: 4
    Sleep Options: Queen Bed in Back and Full Size (Double) Bed
    Air Conditioners: 1
    Awnings: yes
    Length: 30
    Engine Manufacture: Ford
    Leveling Jacks: no
    Exterior Color: Green / White
    Interior Color: Green / Beige
    Price: $28,500
Reply #234
"Gross Vehicle Weight: 12,120"
The GVWR of a 1998 30' is 14050 pounds; the seller likely means that this particular rig weighs 12,120 pounds as currently loaded. This number is not really relevant (IMO).
Reply #235
Looks nice! Can this be a new post since it’s already 10 pages long?
SoCal-Gal  (Tracy)
1991 26.5 RB
Reply #236
The posting is new, the thread is a continuous one, added to whenever someone finds a used LD for sale.
Reply #237
This one is on RV trader....it doesnt say what model it is....
https://www.rvtrader.com/listing/2005-Lazy-Daze-MONTCLAIR-5016755566
When i do a search of the vin....a 30ft rear queen comes up....but the seller is calling it a 2005 26.5 MB......they must not have gotten many calls on it due to it appearing like a.scam....flipper...
They must have traded it in to the dealer that has it now.
The web search shows alot of misc upgrades and repairs that the dealer does not show....when i put the vin in Google this old ad came up....
2005 Used Lazy Daze 26.5 Class C in Washington WA
2017 Casita Spirit Deluxe
2016 Twin King 24ft
2017 Casita Independence Dlx
2004 Midbath 26.5
Reply #238
Nice catch! Great research.  That old ad does say it's a 26' Island bed.  There is a also photo of the schematic. That website has a bunch of dead ads.  The same exact ones have been on there for a year and no one has ever responded back to my emails.   The old ad was for $42K and the new ad is for $39K. The two cities are about 5 hours apart.  Certainly a curiosity.
Reply #239
Just recieved this from a member who saw it on Cl.....it is in my opinion a scam....i sent an email before i fully researched it....i found a 2 year old ad on cl....from Kingsman Az and a higher price. Same exact info in the ad...to the word....sellers name is David....not George.
Lazy Daze 26.5 REAR BATH - rvs - by owner - vehicle automotive sale
Here is the old advertisement from 2 years ago
2005 LAZY DAZE 26.5' Rear Bath - 000 (Kingman) | RV, RVs for Sale | Yuma,...
This is a good example how you can get scammed....they ask for a.deposit....your money is gone.
I am reporting this to cl.
2016 Twin King 24ft
2004 Midbath 26.5
Reply #240
Just got an email from the "George"....probably a flipper...proceed with caution......email reads...
I am the buyer of David’s vehicle.
He was a stickler for maintenance- being a teacher you know.
It was in his wife’s name (Janet) as you remember.
Currently stored at my Prescott home.
We just bought a pull-behind.
The number he gives 480 231 3571 says George Green. When you do a.search for that number it has multiple phone numbers and addresses. All around Az.
Rarely do people have that many Ph # and address ....scammers and flippers.
Also the name George Green is in the obituraries for one of the addresses listed.....scammer
2016 Twin King 24ft
2004 Midbath 26.5
Reply #241
Here's an oldie, but goodie with a nutty price.  Anyone know what this would sell for pre-pandemic? I've only been tracking prices for a year.
 1985 Classic Lazy Daze 20 ft - $16,000 (Conyers)
1985 Classic Lazy Daze 20 ft - rvs - by owner - vehicle automotive...
• Popular Mid-Bath model
• Low mileage – 56,000
• Custom RV with an airplane-grade aluminum body
• Windows everywhere
• Housed on the west coast until October 2020 so minimal rust
• Clean and well-kept
• 2020 Resealed roof
• Other 2020 Updates: New escape hatch, replaced tv antenna, plugs/wires/distributor cap, fuel plump, vacuum lines, generator fuel line/filter/pump, new fans inside, replaced most overhead lights with LEDs, new hatch locks. Fuel filter and belts purchased but not installed.
• Wrap around tinted panorama windows in back, and large dinette window
• Easy to drive. basically a Chevy G30 Van Chassis
• Lots of storage and plenty of inside cabinets
• Lazy Daze has a cult following. over a year's waiting list to buy a new one which will set you back well over $105,000 dollars
• Queen size bed over cab. with ladder and good solid handles to hold on to when getting in our out
• Cheap Living rig, free camping on BLM and Forest Service Lands
• Original Sales Invoice from Factory to 1st buyers. and original owners manuals
 1985 Lazy Daze
condition: fair
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 56100
paint color: white
rv type: class C
size / dimensions: 20 ft
title status: clean
transmission: automatic
Reply #242
Here's one been for sale for 17 days. Seller says camped once, burns oil, perfect fixer-upper.
Naw, Hard pass at any price.
1986 Lazy Daze RV - $16,000 (Huson) Montana
1986 Lazy Daze RV - rvs - by owner - vehicle automotive sale
22' long and built on a Chevy van platform. 68,668 miles. All of the cabinetry has been replaced with beautiful oak, new upholstery throughout, custom wood steering wheel, cedar lined closet, electric fireplace, new Winnebago stainless steel sink, 2 burner gas stove and a new convection/microwave oven. The original refrigerator and freezer still works well. We’ve added a TV that uses a rotating antenna and has a DVD player. It needs some love cosmetically in the cockpit. It also needs help with its electrical system that operates the running lights and dashboard. Original handbook and all receipts for renovations are available. Runs well, but burns oil. The carburetor also needs adjustment. We’ve only camped in it one time and thoroughly enjoyed ourselves. Back and forth to Minnesota twice. Cover included. Perfect as a fixer-upper! Asking $17,000 or best offer.
1986 Lazy Daze Class C
condition: good
drive: rwd
fuel: gas
odometer: 68880
paint color: white
rv type: class C
size / dimensions: 22'
title status: clean
Reply #243
Obviously, people's choices are all over the lot when it comes to repairing, replacing parts, and doing cosmetic upgrades on one's ride, but I seriously do not understand prioritizing "feathers" over "guts". This rig is a 35-year-old oil burner with electrical and carburetion issues (and very possibly other mechanical and systems issues not mentioned), but it has ...
"....cabinetry has been replaced with beautiful oak, new upholstery throughout, custom wood steering wheel, cedar lined closet, electric fireplace, new Winnebago stainless steel sink, 2 burner gas stove and a new convection/microwave oven. ... a TV that uses a rotating antenna and has a DVD player."
YMMV, for sure!  ::)
Reply #244
Hi Bsbets;  FranRam already mentioned this rig in reply #239, as a likely scam. Don't send any deposit money.   See it in person first.  RonB
Reply #245
The mid-bath layout seems timeless.  Anyone know the first year it was introduced?
26 1989 $08K Lazy Daze MID BATH Eugene OR
https://eugene.craigslist.org/rvs/d/springfield-1989-lazy-daze/7332137102.html
Very well maintained Lazy Daze. I have owned it over 20 years. Selling because I don’t drive it much because I bought a smaller RV to drive.
 1989 lazy daze
condition: good
delivery available
drive: rwd
fuel: gas
odometer: 138000
paint color: white
rv type: class C
size / dimensions: 26 feet
title status: clean
Reply #247
 1989 lazy daze
condition: good
delivery available
drive: rwd
fuel: gas
odometer: 138000
paint color: white
rv type: class C
title status: clean
THIS POST HAS ALREADY BEEN REMOVED...FYI
2016 Twin King 24ft
2004 Midbath 26.5
Reply #248
Posted today.
22 1987 $10K Lazy Daze REAR TWIN Sacremento CA 6/21
1987 LAZY DAZE !! - rvs - by owner - vehicle automotive sale
From the seller:
1987 lazy daze camper!! 22’ long! 5.7 Chevrolet V8. One previous owner, on non op! Was driven and owned by a family and she was loved and cared for. 65k miles. Rare dinette that turns into a king bed or 2 twin beds. Has queen bed in bunkhouse. Needs some work here and there but definitely a nice camper. You don’t see these really anymore especially in this condition!! Ac was taken out but the wires are still there for an easy installation. Give me a call or text (916) 374-6585
Reply #249
Again, major league water damage to roof and cabover.  Someone who was good at that type of repair could flip these. RonB
