Topic: Mouse Prevention (Read 258 times) previous topic - next topic
Mouse Prevention
With Spring (yah!) coming upon us soon, I’m looking to try and “mouse proof” the LD.  I know there are various deterrents such as Fresh Cab, LED light strings, etc. but are there any measures that can be taken that act as a physical barrier?  I’m thinking of things such as steel wool in penetrations that physically blocks rodents.  What have you done to prevent critters? 🐀🐀🐀
Re: Mouse Prevention
Greg,
Mice can fit thru extremely small holes - off the top of my head I am remembering something like the size of a dime (but maybe it was a little bigger, but think so small you think no way could even a small mouse get in that spot).
Yes, you could put screens/steel wool everywhere but likely you would miss something and they might just chew another hole for themselves.
Plus you need to protect things like any wiring/plumbing that is outside of the coach "box" as rodents love modern wiring & pex.
The biggest problem is damage in the engine compartment, which is unsealable. Prevention with deterrent is the only option there.
Try one's best, total sealing for mice is impossible. They will find a way in. Set some traps in the LD when not in use. Verification aside, I've kept bags of moth balls in the engine compartment for years and never had rodent damage.
Spring trap inside
Bait station underneath
Keep all potential nesting material, napkins..paper towels...sheets..out of compartments and other easy to find locations.
Try not to let long periods of time pass without inspection.
I've found that [for me] that using RatZapper battery operated traps WORK. I have two inside the stored rig, [one at each end of 31fter.] and one in the engine compartment. I had used flashing lites, irish spring, frequencing sounds, etc. but when I put the traps in, I caught five mice and one rat within a few weeks, about one a week. It's now been three months, and no further rodents, and no sign of any infestation. They work!
Gini Free and Junah, canine xtrodinaire
"Growing old is mandatory. Growing wise is optional."
Here is a suggestion that will hopefully save someone a lot of grief. I have had a couple of air filters chewed up by rodents; I am not sure if it was mice or chipmunks. I think they were attracted either to the adhesive in the filter or the insects in the filter. Find a way to block the air cleaner assembly.
I take several steps when our LD is parked. Here is one I think that is the most important. I remove the snorkel part of the air cleaner where it inserts in the shroud behind the radiator and use old panty hose to block the snorkel. I also put a small sack of moth balls behind that. And most importantly, I put a reminder about this in front of the speedometer so I don't forget to remove it before starting the engine.
Unfortunately, I learned this lesson the hard way. My mechanic has suggested finding a rubber ball that would fit in that snorkel to block rodents from reaching the airfilter. He has seen the problem of chewed air filters often in Rvs.
I have tried " Cabin Fresh" with mixed results. Moth balls seem to deter the critters in my area the best.
Physically blocking openings is a good idea, but DO NOT use steel wool! if it gets damp, It can spontaneously combust, and there goes your rig. Use bronze or copper "mouse mesh."
Don’t you own a cat?
Put it to work.
Newer LDs have few ways to enter the interior.
As Steve pointed out, the engine compartment is the main problem, under the intake manifold is roomy enough for a large family of mice and rats. Starting the engine frequently and letting it warm up will clear existing nests.
Now have a talk with the cat about carrying it’s weight.
Put it to work.
Good point, Larry. I crawled underneath the LD today and everything looked pretty tight in the MB.  I do remember a mouse nesting and having babies in the oven of our '85 TK though; not a pleasant sight.
Our little male is an excellent mouse catcher but we keep him indoors due to the critters that live here. He loves to catch mice in the garage and bring them back into the house to show us.  Maybe I can make a full-time apartment for him in the LD?
I think I'm going to try the mothballs for the engine compartment, as Steve K. suggested.  Starting it up occasionally is a good idea.  Thanks!
Thanks for the tip, Andy!
"Find a way to block the air cleaner assembly."
I had a similar experience. Trouble was after the rodent shredded the air filter, unbeknown to me, the first time I tried to start the engine it sucked the paper particles  through the MAP and into the intake manifold. I had to get my mechanic to do a house call to remedy that one. Then I got a piece ¼" hardware cloth, about six inches square, formed a pocket and stuffed it into the air horn. Anchored it in place with silicon rubber. Haven't had that problem since.  ::)   ;)
Steel wool and batteries (9volt, especially) are a BAD combination!  Learned that one by accident.  I've used fresh cab in the engine compartment of my Pick up and my 2005 LD with pretty decent luck!
2005 RB
"Steel wool and batteries (9volt, especially) are a BAD combination!"
Any Survivalist will tell you that combination is an excellent way to start a fire when other methods fail.  :o
