Topic: Service Engine Codes (Read 1367 times) previous topic - next topic
Re: Service Engine Codes
Concur the 5W-30 oil for 2017 (09/16 chassis build in my case). However, my 2017 E-series owners manual shows spark plugs and rear axle fluid due at 97,500 miles. Then it states that “transmission fluid and filter (5-speed transmission only) every 60,000 miles. Consult dealer for requirements.”
How did you hear about these changes? Is this coming from Ford or your dealer?
I got the information from Ford where you are towing another vehicle.  In our case a 4,000 lb jeep wrangler.  If you are not towing, the mileage goes up.
Ross Taylor
2017 MB
You may want to clean the MAF sensor if the output voltage is out of spec range, accumulated dust could shew the air flow measurement.
https://www.ford-trucks.com/forums/793764-v-10-6-8l-mass-air-flow-sensor-cleaning.html
Also, a vacuum leak is likely as your LD went through some service recently, a careless technician may touch some vacuum tube connectors and cause the leak. To diagnose, have the engine running at idle, spray a small amount of carb cleaner near the vacuum tube connectors, one by one, if the engine suddenly run smooth at that connector, then you find the leak.
Good luck
2004 Mid Bath,
2007 Jeep Liberty Towed
The forum link you provided is talking about a 6.8 liter engine on the F53 chassis. Is that the same as our engine?
No, that was a different engine but the same principle applies. The location of MAF sensor may be different and intake hose routing different.  I could not find a V10 engine in E450 specific posting.
2004 Mid Bath,
Here is a picture of the MAF sensor in the E450 1998-2005 V10 air intake system. The air filter housing must be removed to see the sensor hot wire and thermocouple which need to be cleaned. Please use the CRC MAF cleaner fluid to clean it. Use of carb cleaner or brake cleaner will cause damage to the sensor. Never use cotton swab to clean it. Once you clean the sensor, please make sure all air intake hose connections are tight so no vacuum leaks.
2004 Mid Bath,
As shown many times before,  Ford's service recommendations for your particular year LD can be found here
https://owner.ford.com/tools/account/maintenance/maintenance-schedule.html
On later model V10s, if the MAF voltage is out of spec, it should set a "Check Engine" light (CEL) and leave a readable code.
The hot wire in the MAF is very delicate and can be easily damaged, I would only clean it if a CEL indicates a problem.YMMV
That’s a great resource, thanks for sharing, Larry!
Just drove over to Camp SLO from Tehachapi and while waiting to turn left at the 46/101 junction, I noticed the engine was idling roughly and that the service engine had come on again. Hadn’t had any problems since the last incident in January, even after a February trip to the coast.
These new codes are different than the previous ones. Today I got a P0300 and a P0308 which is a cylinder(s) misfire. Should I go ahead and clear these codes? Is this something I need to deal with right away?
According to this information, 'misfires' with these codes are matters of concern; if my rig were throwing these codes, I would want the problem(s) accurately diagnosed and fixed a.s.a.p.
P0300 – Meaning, Causes, Symptoms, & Fixes | FIXD Automotive
P0308 – Meaning, Causes, Symptoms, & Fixes | FIXD Automotive
Perhaps one of our engine gurus might offer advice?
Hi Greg; so the first question is: have you been fiddlin' with plugs coils or wire lately?   As new and low mileage as your rig is, you shouldn't have any of these codes.   Second question: any sign of rats or mice inhabiting your engine area?   Occam's Razor at work. RonB
Thanks, Joan.
Ron, no fiddling here and no rodent issues as far as I know but I’ll go verify that.
Hello Greg,
Sorry about your issues but didnt this start after you had a smog check done ?.
                                         Jody
A P0308 code is definitely a misfire on cylinder 8.  A bad ignition coil is the usual cause and is a somewhat common problem on the V10s. We carry an extra coil for such occasions. A less likely possibility is a fail fuel injector.
It needs to be checked ASAP before engine damage occurs.
When the Check Engine light comes on, it's always best to immediately determine what is going on, engines are expensive.
Some codes allow continued driving, others don't.
Hello Greg,
                                         Jody
Hi Jody,
Yes but the issues I had right after getting a service and smog were different codes (too lean). I found that the service tech had not clamped down the air filter correctly, and after I fixed it, the problem (it was running rough then also) went away and that code didn’t reappear after I cleared it. I have driven over 500 miles since then with no problem until today.
Based on what I’m hearing, I may miss the MB meetup. Anyone know any good Ford mechanics on the central coast?
Thanks, Larry. Is this something you think I could drive it a short distance to a repair facility or should I consider towing instead?
Greg
Sorry to hear about the trouble. Mullahey Ford in Arroyo Grande - (888) 446-6005 - services Ford Motorhomes.  They’ve been very accommodating with me. I wouldn’t be surprised if they might squeeze you in. And, if they can getrdone, your only 30 miles from Morro Bay.
Good Luck!
Thanks, Warren.  I actually spoke to Mullahey Ford’s service department this morning and was told they no longer service motorhomes. I also spoke with Perry Ford and Paso Ford and got no’s from them as well. Turns out Mullahey Dodge in Paso Robles is willing to look at it but I have made arrangements for tomorrow with Jim Burke Ford in Bakersfield to work on it under warranty. I’ve been told that since the dash light is not flashing that I could drive it carefully but if it starts to flash I need to pull over immediately and get a tow, so that’s what I’m gonna try to do.
Sorry to miss the get together but will try again next year! Guess I need to call and cancel my site, huh?
If the Bakersfield Ford place diagnoses the cause(s) of the codes, please post the outcome. Hope the problem is easily diagnosed and quickly repaired.
Reply #43
[quote author=HiLola link=msg=229232}I’ve been told that since the dash light is not flashing that I could drive it carefully but if it starts to flash I need to pull over immediately and get a tow, so that’s what I’m gonna try to do.
[/quote]
Sorry I didn’t respond earlier, it’s been a busy day.
I would not drive it that far without disconnecting the cylinder’s fuel injector. If the ignition coil has failed and there is no spark, the unburned gasoline will wash the lubricating oil off the cylinder’s wall, destroying the piston’s rings.
This is first hand knowledge, three years ago, coming home from the Morro Bay event, our LD had an ignition failure on one cylinder that didn’t set a code.  The result was a ruined engine that earned Ford $8000.’
Reply #44
Oh boy, how would I do that?  And how would that affect the rest of the engine?
Reply #45
Greg, this is only a suggestion; I have no idea if this shop in San Luis might be able to help, but it might be worth a call to them before you drive over to Bakersfield, particularly if you're not able to disconnect the fuel injector for the #8 cylinder (or any other that is throwing a code). I'm sure this is beyond frustrating, but recalling Larry's experience with 'cylinder wash', I'd try 'local' (out on Tank Farm Road) first.
Reeves Auto Repair San Luis Obispo CA, California, Brake Repair, Oil Change,...
Good luck.
Reply #46
We have decided to let Ford roadside assistance take care of our trip to the Bakersfield Ford dealer. Thank you for all your sage advice and I will post the outcome when I know.
Reply #47
Just an update, Nocona made it safely to the Ford dealership thanks to West Coast Towing out of Atascadero. We are safely back home in Tehachapi waiting to hear something . . .
Reply #48
Heard back from the dealer.  Apparently we had a bad plug in the number 8 cylinder and the engine is now repaired.  We're going to pick it up in the morning and head for Morro Bay again. Keeping my fingers crossed!
Reply #49
That is great news Greg!
I'm glad it was nothing worse.
Harold
