Just saying hello and I love this site! June 25, 2020, 04:19:00 pm Hello,My name is Bill Clugston and I've owned my 2003 Rear Bath 26.5" Lazy Daze since 2004. I would've chatted sooner, but every time I went to ask a question the answer was easily found with a search. This is a very awesome site run by dedicated users!Currently, Wayfarer is being refitted with an upgraded solar power system and general 100k maintenance. I'll post photos of the refit as I have time. The big addition is the jump to a bank of 4 Battle Born lithium iron phosphate batteries and a 3000watt Victron hybrid inverter! It should be a fun install!Later,Bill Clugston 5 Likes
Re: Just saying hello and I love this site! Reply #1 – June 25, 2020, 07:13:51 pm Quote from: bclugston - June 25, 2020, 04:19:00 pmHello,My name is Bill Clugston and I've owned my 2003 Rear Bath 26.5" Lazy Daze since 2004. I would've chatted sooner, but every time I went to ask a question the answer was easily found with a search. This is a very awesome site run by dedicated users!Currently, Wayfarer is being refitted with an upgraded solar power system and general 100k maintenance. I'll post photos of the refit as I have time. The big addition is the jump to a bank of 4 Battle Born lithium iron phosphate batteries and a 3000watt Victron hybrid inverter! It should be a fun install!Later,Bill ClugstonBill, you get the lurker-of-the-year award. You can bet there will be great interest in your new solar system. We have lots of discussions about this topic as you probably have found out. Welcome aboard.Chris 1 Likes
Re: Just saying hello and I love this site! Reply #2 – June 27, 2020, 12:57:41 am Quote from: Chris Horst - June 25, 2020, 07:13:51 pmBill, you get the lurker-of-the-year award. You can bet there will be great interest in your new solar system. We have lots of discussions about this topic as you probably have found out. Welcome aboard.Chris Thanks, Chris, I'd certainly like to help out. This isn't my first solar project, but it is my most complex. I'm also poking around the rig for rot, worn-out components, replacing filters, and topping off fluids. All of the "fun" things an owner of a senior rig gets to do <LOL>! With a little, TLC Wayfarer will probably outlast me!Bill Clugston 1 Likes
Re: Just saying hello and I love this site! Reply #3 – June 27, 2020, 02:12:18 pm Bill,I’ll be getting a similar solar upgrade at AM Solar in about two weeks.Like you I’m shooting for at least 4 Battle Born 100 amp hour lithium’s. What size panels are you installing? I was shooting for Zamp 90’s but now am leaning toward the Zamp 170’s. Only slightly larger than the 90’s but watt for watt the 170’s are about 1/2 the cost per watt. Since you are near AM Solar is this your installer? Keep us posted. Kent 1 Likes
Re: Just saying hello and I love this site! Reply #4 – June 30, 2020, 04:58:56 pm Quote from: Kent Heckethorn - June 27, 2020, 02:12:18 pmBill,Iâll be getting a similar solar upgrade at AM Solar in about two weeks.Like you Iâm shooting for at least 4 Battle Born 100 amp hour lithiumâs. What size panels are you installing? I was shooting for Zamp 90âs but now am leaning toward the Zamp 170âs. Only slightly larger than the 90âs but watt for watt the 170âs are about 1/2 the cost per watt. Since you are near AM Solar is this your installer? Keep us posted. KentHi Kent,No, I'm doing all my own work. I'm pretty familiar with electronics and electrical wiring. I've also built a variety of solar systems. I have done business with AM Solar in the past and they are great folks to deal with, I highly recommend them.I have two 100 watt panels (from AM Solar!) on the system now wired in parallel. I plan to rewire the setup into a series/parallel design. The two 100 watt panels will be wired in series and then paralleled with two 170 watt panels from Amazon (BougeRV Amazon.com : BougeRV 170 Watts Monocrystalline Solar Panel 12 Volts Mono... ) also wired in series. Fortunately, all panels have the same voltage output. I almost forgot to check for that issue ;D If I like the BougeRVs, I may swap out the existing the 100 watt panels for two more BougeRVs. The two 100 watt panels can then be used in a remote astrophotography observatory (my primary hobby).Later,Bill As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Just saying hello and I love this site! Reply #5 – June 30, 2020, 08:24:30 pm Quote from: bclugston - June 25, 2020, 04:19:00 pmCurrently, Wayfarer is being refitted with an upgraded solar power system and general 100k maintenance. I'll post photos of the refit as I have time. The big addition is the jump to a bank of 4 Battle Born lithium iron phosphate batteries and a 3000watt Victron hybrid inverter! It should be a fun install!Welcome aboard.I have done a few of these systems and advise buying a pro grade crimper and cable cutter. Those huge lugs are hard to crimp effecively any other way. Cable cutters produce a straight, clean cut.Specialty tools needed for inverter installation | Top- adju… | FlickrPost some photos when you are finishedLarry
