Screw new Fantastic Vent into the roof ? June 17, 2020, 04:16:18 pm Hi Everyone,Today I'm removing the old brittle swamp cooler from our 93 RB, and by tomorrow will add a new Fantastic Vent in it's place. I'm a bit uneasy about putting a dozen new screw holes into the roof, and wonder if anyone would recommend other ways. I just saw on Cheap RV Living that someone was using 3M VHB tape to adhere a solar panel to a fiberglass roof. Any guidance is appreciated. Now I'll get back to the roof with my hammer, crowbar, etc. and see if can complete getting the cooler off and prep the surface. Will check back later.Thanks in advance,Pete
Re: Screw new Fantastic Vent into the roof ? Reply #1 – June 17, 2020, 05:23:16 pm Bed the fan’s base in sealant and press down so the excess sealant oozes out, now screw it to the roof. Bury the screw heads in sealant. This is how the Mothership does it.Mask the outline of the base with masking before to ease cleanup.Double sided tape will not guarantee a water tight seal nor be as strong.Larry 1 Likes
Re: Screw new Fantastic Vent into the roof ? Reply #2 – June 17, 2020, 06:02:50 pm Larry, would you use 3M5200 FC or some other sealant?Jon
Re: Screw new Fantastic Vent into the roof ? Reply #3 – June 17, 2020, 06:21:24 pm Quote from: JonS - June 17, 2020, 06:02:50 pmLarry, would you use 3M5200 FC or some other sealant?Jon3M 5200 FC is my go to sealant.Larry
Re: Screw new Fantastic Vent into the roof ? Reply #4 – June 17, 2020, 06:29:05 pm Where do they sell it? Thanks.
Re: Screw new Fantastic Vent into the roof ? Reply #5 – June 17, 2020, 06:49:23 pm I got mine from Amazon. Maybe get several extra and calk your windows and end caps.Jon
Re: Screw new Fantastic Vent into the roof ? Reply #6 – June 17, 2020, 08:37:08 pm Quote from: Peter Weisel - June 17, 2020, 06:29:05 pmWhere do they sell it? Thanks.My local Lowes stocks 3m 5200 Fast Cure. You might check a Lowes near your location.
